Hi Folks, I’m new to the forums and I’ve had HA for a few years now but still really bad at figuring out YAML stuff.
The Ecobee integration is working great, but it doesn’t show the “equipment_running” attribute anywhere that i can find except in the developer tools, Ecobee-states section. Is this just a defect on my install or does it not show that info on anyone’s HA? I could use some help fixing that if it’s just mine.
If I need to make a template or do a manual YAML entry to show “equipment_running” info I would need 100% help with that if someone would be so kind. I think if that’s the case it would help me greatly in understanding that stuff.
My goal is to see a daily, weekly, monthly, yearly total and current state and distinguish between stage1 and stage2 of the “equipment_running” info in a vertical history graph because it shows what stage the AC compressor and heater is in (stage1 and stage2) and I’m not sure if a horizontal history graph would work all that great with the visual aspect of comparing the 2 stages of AC and heat.
Its an Ecobee lite 3
using HA on windows VM
Core 2024.4.3
Supervisor 2024.04.0
Operating System 12.2
Frontend 20240404.2
Thank you for having a look at my post!
