Not sure if this is by design? with the Ecobee weather card, but it appears to be missing the forecast icons between the day and the high/low tempature.
No idea how to fix but I have also had this issue since I set up the ecobee component.
I have the same issue. Did you figure out how to fix it?
I just noticed this too. I think the problem is the ecobee weather component needs to massage the conditions it returns. Where I am, it’s currently returning partly cloudy overnight
instead of partlycloudy
I’ve pasted the start of a fix at the end of this comment, you need to replace homeassistant/components/weather/ecobee.py
with the code.
I say start because I’ve only been able to map Ecobee to Home Assistant weather that is actually happening where I live. If you use the new code you can tell what weather isn’t mapped by looking in the logs or, for docker, you can also run this command:
docker logs home-assistant 2>&1 | grep unhandled-cond
And you’ll see output like this:
2019-02-26 11:10:11 INFO (MainThread) [eweather] unhandled-cond=light snow (< 1 in.) in the evening.
After I map a few more weather descriptions and, assuming this is the correct fix, I’ll create a pull request to get this into the official release.
Support for displaying weather info from Ecobee API.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/weather.ecobee/
import logging
from datetime import datetime
from homeassistant.components import ecobee
from homeassistant.components.weather import (
ATTR_FORECAST_CONDITION, ATTR_FORECAST_TEMP, ATTR_FORECAST_TEMP_LOW,
ATTR_FORECAST_TIME, ATTR_FORECAST_WIND_SPEED, WeatherEntity)
from homeassistant.const import TEMP_FAHRENHEIT
_LOGGER = logging.getLogger('eweather')
DEPENDENCIES = ['ecobee']
ATTR_FORECAST_TEMP_HIGH = 'temphigh'
ATTR_FORECAST_PRESSURE = 'pressure'
ATTR_FORECAST_VISIBILITY = 'visibility'
ATTR_FORECAST_HUMIDITY = 'humidity'
MISSING_DATA = -5002
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Set up the Ecobee weather component."""
if discovery_info is None:
return
dev = list()
data = ecobee.NETWORK
for index in range(len(data.ecobee.thermostats)):
thermostat = data.ecobee.get_thermostat(index)
if 'weather' in thermostat:
dev.append(EcobeeWeather(thermostat['name'], index))
add_entities(dev, True)
class EcobeeWeather(WeatherEntity):
"""Representation of Ecobee weather data."""
def __init__(self, name, index):
"""Initialize the Ecobee weather platform."""
self._name = name
self._index = index
self.weather = None
def get_forecast(self, index, param):
"""Retrieve forecast parameter."""
try:
forecast = self.weather['forecasts'][index]
return forecast[param]
except (ValueError, IndexError, KeyError):
raise ValueError
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def condition(self):
"""Return the current condition."""
try:
return ew_to_ha( self.get_forecast(0, 'condition') )
except ValueError:
return None
@property
def temperature(self):
"""Return the temperature."""
try:
return float(self.get_forecast(0, 'temperature')) / 10
except ValueError:
return None
@property
def temperature_unit(self):
"""Return the unit of measurement."""
return TEMP_FAHRENHEIT
@property
def pressure(self):
"""Return the pressure."""
try:
return int(self.get_forecast(0, 'pressure'))
except ValueError:
return None
@property
def humidity(self):
"""Return the humidity."""
try:
return int(self.get_forecast(0, 'relativeHumidity'))
except ValueError:
return None
@property
def visibility(self):
"""Return the visibility."""
try:
return int(self.get_forecast(0, 'visibility'))/1000
except ValueError:
return None
@property
def wind_speed(self):
"""Return the wind speed."""
try:
return int(self.get_forecast(0, 'windSpeed'))
except ValueError:
return None
@property
def wind_bearing(self):
"""Return the wind direction."""
try:
return int(self.get_forecast(0, 'windBearing'))
except ValueError:
return None
@property
def attribution(self):
"""Return the attribution."""
if self.weather:
station = self.weather.get('weatherStation', "UNKNOWN")
time = self.weather.get('timestamp', "UNKNOWN")
return "Ecobee weather provided by {} at {}".format(station, time)
return None
@property
def forecast(self):
"""Return the forecast array."""
try:
forecasts = []
for day in self.weather['forecasts']:
date_time = datetime.strptime(day['dateTime'],
'%Y-%m-%d %H:%M:%S').isoformat()
forecast = {
ATTR_FORECAST_TIME: date_time,
ATTR_FORECAST_CONDITION: ew_to_ha(day['condition']),
ATTR_FORECAST_TEMP: float(day['tempHigh']) / 10,
if day['tempHigh'] == MISSING_DATA:
break
if day['tempLow'] != MISSING_DATA:
forecast[ATTR_FORECAST_TEMP_LOW] = \
float(day['tempLow']) / 10
if day['pressure'] != MISSING_DATA:
forecast[ATTR_FORECAST_PRESSURE] = int(day['pressure'])
if day['windSpeed'] != MISSING_DATA:
forecast[ATTR_FORECAST_WIND_SPEED] = int(day['windSpeed'])
if day['visibility'] != MISSING_DATA:
forecast[ATTR_FORECAST_WIND_SPEED] = int(day['visibility'])/1000
if day['relativeHumidity'] != MISSING_DATA:
forecast[ATTR_FORECAST_HUMIDITY] = \
int(day['relativeHumidity'])
forecasts.append(forecast)
return forecasts
return None
def update(self):
"""Get the latest state of the sensor."""
data.update()
thermostat = data.ecobee.get_thermostat(self._index)
self.weather = thermostat.get('weather', None)
def ew_to_ha( cond ):
cond = cond.lower()
_LOGGER.info( 'cond=' + cond )
if cond.startswith('snow') or cond.startswith('light snow'):
return 'snowy'
if cond.startswith('partly cloudy'):
return 'partlycloudy'
if cond.startswith('mostly cloudy'):
return 'cloudy'
if cond.startswith('breezy'):
return 'windy'
if cond.startswith('clear'):
return 'clear-night'
_LOGGER.info( 'unhandled-cond=' + cond )
return cond
I hate to revive an old thread but many updates along and I still have this problem, is this the only official fix currently? I would LOVE to have my icons back
Looks like this has been corrected in 0.101.1. I now have the icons displaying.
