Ecoflow API
Hi there. I was wondering if anyone had any luck with the Ecoflow Integration. Since the ports have been closed the only way to get the data is via the API. I received all the data to do a curl get-x but I am not able to convert this data into any sensor. Don’t know where to start… Any help would be appreciated. Thanks and have a good festive season. Thanks.
Same issue here: I would like to integrate my Smart Home Panel and Delta Pro with add-on battery. I’m looking for the API-integration from Ecoflow. Integrating your home batteries - Home Assistant
Hi everyone. I am new into home assistant and also a new owner of a delta max battery.
I have been reading a lot and my conclusion is that we have no other way that use the API. I am trying to convert the output to a sensor so we can turn on/off a smart plug so control charge/discharge.
