Home Assistant 2022.3.06, Zwavejs2mqtt, zwavejs2mqtt: 6.6.2, zwave-js: 8.11.9
Device: “productLabel”: “TILT-ZWAVE2.5-ECO”,“productDescription”: “Z-wave Plus Gold Plated Reliability Garage Door Tilt Sensor”, “manufacturer”: “Ecolink”, “firmwareVersion”: “10.1”,
Problem: Yesterday the Garage Door close signal was missed, resulting in Home Assistant believing the garage door was open. The entity unique ID in HA is “4060453304.5-113-0-Access Control-Door state.22”. System has been running for several months and this is the first time the issue has occurred.
Looking at the zwavejs debug log, I can see the garage door close messages come through, but the close message at 18:08 did not update this entitiy, whereas the close message at 22:12:45 did.
Did a message get dropped in zwave? Or is this a problem (may have been fixed) with zwave_js?
The log has 4 sets of messages.
18:04:17 - the garage door opening
18:08:14 - the garage door closing - that did not update HA
22:11:46 - The garage door opening
22:12:45 - The garage door closing with proper notifications
Entity Registry Entry
"area_id": null,
"capabilities": null,
"config_entry_id": "dadc55859f16cfa54fc9f36de4e2e13d",
"device_class": null,
"device_id": "3f15921a05af9cdf5ce820bcac910621",
"disabled_by": null,
"entity_category": null,
"entity_id": "binary_sensor.garage_door_sensor",
"icon": null,
"id": "70765e329880aa179246786661de7e36",
"name": "Garage Door Sensor",
"options": {},
"original_device_class": "door",
"original_icon": null,
"original_name": "garage_door: Access Control - Window/door is open",
"platform": "zwave_js",
"supported_features": 0,
"unique_id": "4060453304.5-113-0-Access Control-Door state.22",
"unit_of_measurement": null
zwavejs debug log
Garage Door Opening
2022-05-27T18:04:17.103Z SERIAL « 0x0111000400050b7105000000ff06160000007f (19 bytes)
2022-05-27T18:04:17.103Z CNTRLR [Node 005] [~] [Notification] notificationMode: "push" [Endpoint 0] [internal]
=> "push"
2022-05-27T18:04:17.103Z SERIAL » [ACK] (0x06)
2022-05-27T18:04:17.104Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
└─[NotificationCCReport]
notification type: Access Control
notification status: 255
notification state: Window/door is open
2022-05-27T18:04:17.105Z CNTRLR [Node 005] [~] [Notification] Access Control[Door state]: 23 => 2 [Endpoint 0]
2
2022-05-27T18:04:17.322Z SERIAL « 0x010a00040005043003ffffc3 (12 bytes)
2022-05-27T18:04:17.323Z CNTRLR [Node 005] [Binary Sensor] Any: metadata updated [Endpoint 0]
2022-05-27T18:04:17.324Z CNTRLR [Node 005] [~] [Binary Sensor] Any: false => true [Endpoint 0]
2022-05-27T18:04:17.324Z SERIAL » [ACK] (0x06)
2022-05-27T18:04:17.325Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
└─[BinarySensorCCReport]
type: Any
value: true
Garage Door Closing (Access Control[Door state] not updated)
2022-05-27T18:08:14.068Z SERIAL « 0x0111000400050b7105000000ff06170000007e (19 bytes)
2022-05-27T18:08:14.069Z CNTRLR [Node 005] [~] [Notification] notificationMode: "push" [Endpoint 0] [internal]
=> "push"
2022-05-27T18:08:14.069Z SERIAL » [ACK] (0x06)
2022-05-27T18:08:14.070Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
notification state: Window/door is closed
2022-05-27T18:08:14.090Z SERIAL « 0x010a0004000504300300ff3c (12 bytes)
2022-05-27T18:08:14.090Z CNTRLR [Node 005] [Binary Sensor] Any: metadata updated [Endpoint 0]
2022-05-27T18:08:14.091Z CNTRLR [Node 005] [~] [Binary Sensor] Any: true => false [Endpoint 0]
2022-05-27T18:08:14.092Z SERIAL » [ACK] (0x06)
2022-05-27T18:08:14.093Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
type: Any
value: false
Garage Door Opening
2022-05-27T22:11:46.474Z SERIAL « 0x0111000400050b7105000000ff06160000007f (19 bytes)
2022-05-27T22:11:46.476Z CNTRLR [Node 005] [~] [Notification] notificationMode: "push" [Endpoint 0] [internal]
=> "push"
2022-05-27T22:11:46.476Z SERIAL » [ACK] (0x06)
2022-05-27T22:11:46.477Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
2022-05-27T22:11:46.479Z CNTRLR [Node 005] [~] [Notification] Access Control[Door state]: 22 => 2 [Endpoint 0]
2
2022-05-27T22:11:46.495Z SERIAL « 0x010a00040005043003ffffc3 (12 bytes)
2022-05-27T22:11:46.496Z CNTRLR [Node 005] [Binary Sensor] Any: metadata updated [Endpoint 0]
2022-05-27T22:11:46.497Z CNTRLR [Node 005] [~] [Binary Sensor] Any: false => true [Endpoint 0]
2022-05-27T22:11:46.498Z SERIAL » [ACK] (0x06)
2022-05-27T22:11:46.498Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
type: Any
value: true
Garage Door Closing
2022-05-27T22:12:45.122Z SERIAL « 0x0111000400050b7105000000ff06170000007e (19 bytes)
2022-05-27T22:12:45.123Z CNTRLR [Node 005] [~] [Notification] notificationMode: "push" [Endpoint 0] [internal]
=> "push"
2022-05-27T22:12:45.123Z SERIAL » [ACK] (0x06)
2022-05-27T22:12:45.123Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
2022-05-27T22:12:45.124Z CNTRLR [Node 005] [~] [Notification] Access Control[Door state]: 22 => 2 [Endpoint 0]
3
2022-05-27T22:12:45.143Z SERIAL « 0x010a0004000504300300ff3c (12 bytes)
2022-05-27T22:12:45.144Z CNTRLR [Node 005] [Binary Sensor] Any: metadata updated [Endpoint 0]
2022-05-27T22:12:45.144Z CNTRLR [Node 005] [~] [Binary Sensor] Any: true => false [Endpoint 0]
2022-05-27T22:12:45.145Z SERIAL » [ACK] (0x06)
2022-05-27T22:12:45.145Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
type: Any
value: false
2022-05-27T22:12:53.829Z SERIAL « 0x010c0004000f063105012200b35a (14 bytes)
In the log I also saw, that a Binary SensorCC report was coming through, so I enabled the disabled “any” entity in HA for this. And as a short-term mitigation, I’ve added logic to look a both signals and report when they don’t match.
"area_id": null,
"entity_id": "binary_sensor.garage_door_any",
"icon": null,
"id": "86852f8a2b8a3fdc4e77fc9a375a3f35",
"name": null,
"options": {},
"original_device_class": null,
"original_name": "garage_door: Any",
"unique_id": "4060453304.5-48-0-Any",
