I have 2 Ecolink PIR Motion Sensors connected for Z-Wave in my Home Assistant running on my Raspberry Pi 3. I’m confused about two things though:
- How do I adjust the
wake_up_interval
? My initial Ecolink PIR Motion Sensor has a wake_up_interval
is set to 14400
and the one that I just added the other day is set to 3600
- The first motion sensor shows up as
binary_sensor.ecolink_pir_motion_sensor_sensor_2_0
inside of Hass, however, the new one shows up as binary_sensor.ecolink_unknown_type0004_id0001_sensor_3_0
Why does the 2nd Ecolink PIR Motion Sensor show up as this unknown_type
My configuration.yaml
can be found here.
My customize.yaml
can be found here.
Thanks!
Have you tried using open-zwave-control-panel to modify the configuration? also try saving it after. also, sometimes it takes a couple restarts of HA before it sees the correct type i believe.
@nVINCEble Yeah, I’ve tried to update the name and wake_up_interval
from the Open Z-Wave Control Panel to no avail.
I did notice that the first Ecolink Motion Sensor is NOT a Z-Wave Plus model. However, the new Ecolink Motion Sensor IS a Z-Wave Plus Model.
Any other ideas?
Thanks!
Are both the same model? You could try to check the ecolink site and see if there is a firmware update. If they r both the same model then u could try to remove and then re add the node that shows as unknown.
I can’t find any firmware updates for Ecolink, unfortunately.
The new one appears to be Z-Wave Plus. @nVINCEble
