Does anyone have any experience with this particular model of door sensor? I cant seem to get it to pair. The instructions don’t mention a pairing mode for the unit. It only says to move the magnet away from and back to the sensor repeatedly for enrolling. I have tried to add it multiple times also attempting to use secure inclusion. I know the battery is good and the device is very close to my Zwave USB stick. Any suggestions would be much appreciated.
Have you followed this guide?
- Start by placing the controller into inclusion mode
- Activate inclusion mode for the sensor by removing the plastic pull-tab from the back of the sensor. When the inclusion process is complete, the LED on the sensor will be solid blue, then go out.
- Test the sensor. Place the magnet next to the sensor to represent a closed position (see Installation section to see where to position the magnet). If the LED flashes ONE TIME, it is successfully communicating on your Zwave network. If the LED on the sensor flashes slow and steady for 5 seconds, you need to repeat the inclusion process.
Note: If you need to repeat the inclusion process, repeat STEP ONE above, then for STEP TWO you will need to simply remove the cover of the sensor, remove the battery for 10 seconds, reinsert the battery, and replace the sensor cover. This will re-enter the sensor in inclusion mode
So OP, did it work? I’m thinking of buying this.
Did you have any luck with this? My house had these preinstalled but I just removed the 2gig alarm panel b/c I’d like to manage these sensors myself. Thanks!
Another interested party. Can’t seem to get them to pair, and ardysusilo’s guide doesn’t exist (and is for the wrong sensor).
@Darkmx-6 @morissette @swampjedi
Never got it to work. Device ended up in the circular file cabinet
thanks for the reply
WST-212 Door Sensor is actually a 345Mhz sensor type not ZWave but will pop up when looking for ZWave Door Sensors.
