I purchased a Econet Bulldog Zwave Water Valve. In Home Assistant, I use the Zwave Integration with and the Aeotec zwave usb stick. The Econet Bulldog paired with Home Assistant and listed it as Node2 . When looking at it there are NO listed controls. Its online and live. Looking around Im not finding much information on others who have paired the Econet Bulldog in the same manner. Curious to know how can I get the controls for this device within Home Assistant.
So the short and sweet version is until a successful interview happens so the device is identified that’s what you’ll see.
Remedy is re-interview until the correct device type is identified.
If a reinterview didn’t do it something is giving you problems with communication (Happens a lot)
Run a ZWave repair on the node, try again.
If it doesn’t pop then I’d pop ZWaveJS into debug logging and capture a log while you’re running an interview to see what’s going on.
Common issues you can fix quickly include:
ZWave stick plugged directly into PC/Pi/etc. Without extension cord usb interference prevents interview
Too far between powered repeaters and signal issues prevent interview
