The Econet integration has been working fabulously to control my furnace for the last few months. It doesn’t appear to connect and has a persistent ‘failed setup, will retry’ notification. I can still control my furnace through the official Rheem Econet app, but I prefer not to!
Has anyone else experienced this? I’ve restarted HA many times but it has done nothing.
I assume this integration uses the pyeconet library? I’ve been using that library with OpenHAB for a year now without problem. But starting a few days ago, I started getting an “invalid response error” from the Rheem API “getLocation” endpoint. I posted my issue to Reddit in the hopes someone would have a solution, but so far no luck: https://www.reddit.com/r/homeassistant/comments/17g8vdk/rheem_pyeconet_api_stopped_working_with_invalid/
I suspect that Rheem has made some change on the backend of their API which has broken the API that pyeconet library uses. Since pyeconet uses an un-official, un-supported API, I’m completely uncertain whether Rheem will fix the issue. I knew this was a risk when I started using pyeconet, but I was hoping that this day would never come. I certainly hope it gets fixed.
EDIT: Oh, I checked the other thread that was linked, and it looks like the pyeconet lib was fixed.
