Hi there!
I’d like to share EcoTerm, a custom integration that brings your EcoTerm meter data into Home Assistant: water meters, heat meters and heat cost allocators, one device per meter.
Features
For every meter in your EcoTerm account the integration creates a device with:
- Meter reading — the latest cumulative reading. It uses the water device class for m³ and the energy device class for kWh / GJ / MWh, so it can be added straight to the Energy dashboard.
- Consumption — consumption for the reported period.
- Adjusted consumption — adjusted period consumption, when EcoTerm provides it.
- Meter problem — a binary sensor that turns on when the latest reading reports a device error. Its attributes contain the hexadecimal error code, the device type and decoded error descriptions (when EcoTerm provides definitions for the error bits).
- Period start / Period end — diagnostic date sensors showing which period the latest reading covers.
Heat cost allocator readings (HCA units) are allocation units, not a direct measurement of energy, so they are exposed as they are and are not converted to kWh.
Diagnostics download is supported (sensitive data is redacted), and the UI is available in English and Czech.
Good to know
- Data comes from the EcoTerm cloud (
cloud_polling). You choose the refresh interval during setup, from 1 to 24 hours, 1 hour by default. - EcoTerm reports readings per period, so values change when a new period report arrives, not continuously. This is a source of meter reports, not a live flow sensor.
- Each physical meter is a separate device. If a meter is replaced, the new one appears as a new device. For the Energy dashboard just add both Meter reading sensors and the history stays continuous.
Installation
Requirements:
- Home Assistant
2026.11or newer. - An EcoTerm API key.
Add the GitHub repository as a custom repository in HACS (category Integration):
Then restart Home Assistant, go to Settings → Devices & services → Add integration, select EcoTerm, enter your API key and the refresh interval.
The integration is young, so I’d really appreciate feedback, ideas and bug reports, especially from people with different meter types (heat meters, HCA) and error codes I haven’t seen yet.
Thanks!
