First attempt at HomeAssistant so be gentle
All I’ve done so far is successfully add my Hues Hub and Light bulb - yeah !!!
Tried to add my Ecovacs Deebot 711. Ecovacs worked and I have the Integration. It shows just my logon name and that’s it. No options to see the vaccuum or anything.
Followed Ecovacs - Home Assistant
Again, did I miss a step? Is there something from the command line I need to do? I found the git entries for the python code but I have no idea what to do with that.
Does anyone have any advice on this? Again, I just purchased the Home Assistant Green and am still geting it setup so if you’re going to tell me to edit a file, then you need to tell me where the file is too.
I managed to get Deebot connected - at least showing up in Devices on Home Assistant - but there are no actual Vaccuums. According to the guide, it should automatically add any device registered to my Deebot account. When I log on to ecovacs.com I don’t see my device. I did register it but it’s not there. Maybe because I didn’t buy it from Ecovacs?
I sent support an email too but figured I’d ask here - although no one has replied to the other request yet so not expecting too many people running Home Assistant have Deebots.
