Just sharing what I did since they now include Ecovacs as a standard integration.
The card I was using no longer worked so this is my solution…
If it helps you at all I’ll be happy…
If you can/want to make any improvements on it please feel free to share!!
It shows your map, status, battery and brushes… hold action on cards will ask for confirmation and if you hit ok it will reset your brushes and filter…
On the right is the rooms that I clean and they call the spot cleaning scripts…
All are available on github…follow the Ecovacs Setup link below
Thank you all!!
