For my Ecovacs vacuum T8 I’m using ecovas official Integration which works very well. I have only one issue or specific use case.
I have some automation to send me an image entity as notification to my Iphone using companion app. From some time this integration introduce svg format for vacuum map for better resolution. My problem is that iphone notification service doesn’t support svg format (only jpg and png, the same is with android).
So my question is how to convert vacuum_map.svg to vacuum_map.png (jpg) directly on device (Rpi4 running Home Assistant OS). I have tried every AI service out there (ChatGPT, Claude, Copilot, Gemini) and none of the solution they introduce is working. I have tried to build custom addon for image converting, trying with python scripts but without any success. Maybe someone can point me in right direction or already have this accomplished. Thanks in advance
