Ecowitt integration doesn't create any sensors
Hi everyone,
I have an Ecowitt GW2000 and a WS69.
As I wrote in the object, I configured the integration and reported the parameters (Server IP / Host Name, Path, and Port) within the configuration web interface as required by the integration configuration guide.
Home Assistant, however, does not create any new sensors.
I would like to point out that from the web interface and from the Ecowitt iOS App I can correctly view all the data so it is certain that it is an integration/communication problem between the GW2000 and Home Assistant.
Anyone have any suggestions? Even just some ideas on how to troubleshoot.
Thank you
Matteo
If you add a new integration, you sometimes have to restart Home Assistant to get everything loaded into memory.
I have one and remember the on-boarding to go much better with the core Ecowitt Integration, lots of sensors coming from the little hub.
https://www.wunderground.com/dashboard/pws/KWIWAUKE234.
