Have a nice day.
I changed position in the gateway of the weather station and sometimes the station loses communication with the base. I would like to be able to see the signal quality between gateway gw2000a and weather station.
Thank you in advance for your time!!!
I’m not sure that information is available, but you can raise an issue on it here.
in the ecowitt application if you are connected to the same network as the weather station it is available as information
yes, understood - it’s also available in the web app…
…but it may not be available as a sensor to the weather services (from Ecowitt’s side).
Either way, the way to find out is via the link I posted.
if I’m not on the same network as the station I can’t see it. also I would like to have statistics with the signal quality
Raise all your requests at the link I posted above.
