So I updated home assistant and was greeted by this after the ecowitt integration failed to load
I manually added some version thing to the previous version because home assistant wouldn’t boot otherwise.
Logger: homeassistant.setup
Source: setup.py:173
First occurred: 11:31:02 PM (1 occurrences)
Last logged: 11:31:02 PM
Setup failed for ecowitt: Unable to import component: cannot import name ‘VOLT’ from ‘homeassistant.const’ (/usr/src/homeassistant/homeassistant/const.py)
What does this mean and how does one fix it exactly…
maybe is my homeassistant, i have Ecowitt Weather Station in hacs, but in configuration/integration + new integration, cant found ecowit after upgrade home assistant
Yes that’s because of one of two things. Of you updated ecowitt then you need to change the manifest.json. you need to add a version. If you upgraded home assistant you need to replace the references to volt with, whatever I said a few posts back on this question here. Also if you don’t know why you need to look at the logs. And then click load all logs or whatever it says at the bottom to see what the issue is. If it says something about a version in relation to ecowitt you need to cha get the version thing. If it says something about volt you need to change 12 references to the word volt to, umm, this “ELECTRIC_POTENTIAL_VOLT” because of something that was updated in home assistant. Look at your logs.
I’ve updated to version 0.7 and all references are already named ELECTRIC_POTENTIAL_VOLT. The version is also included in the manifest. What do I miss?
