Ecowitt2mqtt: Send data from an Ecowitt device to MQTT
It looks like the author of the HA add-on needs to update his code to be able to input MQTT credentials; I recommend creating an issue in that repo: https://github.com/smarthall/hassio-addons/issues
Hi Aaron,
Thanks for your help I’ll head on over and do that.
Great work BTW, - this add on got me over the line with the purchase of the Ecowitt Gw1000 and associated sensors. - Until now I wasnt sure which hardware and how I was going to integrate.
I’ll upload some pics of the card and the sensors in situ when this is working. - Hopefully the ‘Author of the code’ can sit back and appreciate the how he has helped others…
If you have nothing better to do for 5 minutes, read here
specifically the content of Para 7… THACF…
J.
The addon now allows manual configuration of the MQTT Broker details ( IP, port, user. P/W) directly for situations where the MQTT broker is separate to the HA node.
Tested and works.
Thanks to the Coder…
J
Excellent! Glad everything is in action and you’re enjoying it.
I try to run ecowitt2mqtt into a container using portainer.
Running the container stops with error “Missing required environment variable: either MQTT_TOPIC or HASS_DISCOVERY”
If I add those variables it deletes them strangely enough and starting all over with the same error.
Anybody any suggestions what I am doing wrong?
Regards
I don’t use Portainer, but have you tried this? https://www.reddit.com/r/docker/comments/gy53r7/how_to_edit_environment_variables_in_portainer/
This one broken again? Upon clicking install it just spins the circle then never installs
I don’t know which “this” you’re referring to – ecowitt2mqtt or the hass.io add-on?
sorry, hass.io addon :slight_smile:
I see you already posted an issue in that repo. :+1:t2:
Released 1.1.0 today. Marquee features:
  • Better detection of device classes in HASS (i.e., temperature sensors will show up as temperature sensors – icons, etc. – automatically)
  • Support for “binary batteries” (batteries that are either “OK” or “Low”)
  • Support for the HASS device registry
I am so happy that you have made the effort to make this accessible to people and simplify the installation process for less technical like myself. Congrats!
I have my Ecowitt2mqtt running and data is flowing through fine but there is no preceding name to the sensors.
I have a question which probably shows my lack of knowledge:
My mqtt message is as follows and as a result my sensors are all over the place and do not have ecowitt2mqtt in the topic to allow them to be found easily.
How would I go about adding this so that for example in Developer Tools:
sensor.monthlyrain becomes:
sensor.ecowitt2mqtt_monthlyrain
Any help appreciated.
homeassistant/sensor/F6F882B3BA6EF58E2916363883A01CE5/tempin/config at 2:29 PM:
“availability_topic”: “homeassistant/sensor/F6F882B3BA6EF58E2916363883A01CE5/tempin/availability”,
“icon”: “mdi:thermometer”,
“name”: “tempin”,
“qos”: 1,
“state_topic”: “homeassistant/sensor/F6F882B3BA6EF58E2916363883A01CE5/tempin/state”,
“unique_id”: “F6F882B3BA6EF58E2916363883A01CE5_tempin”,
“unit_of_measurement”: “°C”
Thank you for doing this and sharing. The other custom component I was using stopped working. I just followed the instructions to add your repository, and set it up quickly, without issues.
Thanks all for the nice work.
However…I am still not able to get it working on my system.
I prefer the methode of using the add-on “GitHub - smarthall/hassio-addons: Addons for Hassio that I've made/modified” but each time I try to use the link my system give : invalid repository.
Anybody had the same?
Solution?
Herbert
I can’t get this to work and I feel like I missing something obvious?
I tried to install docker in Unraid using this:
root@localhost:# /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker run -d --name='ecowitt2mqtt' --net='bridge' -e TZ="America/Denver" -e HOST_OS="Unraid" -e 'MQTT_USERNAME'='ha' -e 'MQTT_BROKER'='192.168.1.9' -e 'MQTT_PASSWORD'='password' -e 'HASS_DISCOVERY'='true' -p '8080:8080/tcp' 'bachya/ecowitt2mqtt'`
I have also tried to install using portainer using both of these options:
docker run --name ecowit -e MQTT_BROKER=192.168.1.9 -e MQTT_USERNAME=ha -e MQTT_PASSWORD=password -p 8080:8080 -e HASS_DISCOVERY=true bachya/ecowitt2mqtt:latest
docker run --name ecowit -e MQTT_BROKER=192.168.1.9 -e MQTT_USERNAME=ha -e MQTT_PASSWORD=password -p 8080:8080 -e MQTT_TOPIC=ecowitt bachya/ecowitt2mqtt:latest
The docker does start, but if I check logs it’s always empty, and running MQTT Explorer shows no topic being created or data being sent. I know that my broker IP/port, username/password are correct because I have them configured for bunch of other stuff.
Any ideas?
I implemented ecowitt2mqtt into UNRAID using docker with the following settings: Name: ecowitt2mqtt; Repository: bachya/ecowitt2mqtt; Console Shell Command: Shell. The goal was to talk to my home assistant instance on a second NUC running HASSOS. I used the following container variable labels and values: LOG_LEVEL: INFO; MQTT_PORT: 1883 MQTT_PASSWORD: my.password; MQTT_USERNAME: my.mqttuser; MQTT_TOPIC: ecowit2mqtt; MQTT_BROKER: ip.addr; PORT: device port. The device port is what I used on my Ecowitt GW1000 when setting it up. This all worked well for me for a long time. I am having an issue which I will post in a separate message. Hope this helps you gain success with UNRAID and this great docker program.
As mentioned above, I have been using ecowitt2mqtt in a docker container for many months, My gw1000 is on firmware 1.6.8 and has been for over a year. This integrated into Home Assistant right off the bat and reports on both the GW1000 and a secondary sensor I have. Until - a couple of months ago when my battery entity started reporting as “unknown”. In the Ecowitt website it still reports the battery as “Normal” but I see in mqtt where the batt1 value is being reported as “off”. As a binary sensor I suspect it needs to be reporting 1 or 0 instead. Has anyone else had similar problems and were you able to resolve it? Other than updates to the ecowitt2mqtt app I have not changed anything on this integration. I did not notice it immediately so I do not know if a docker version upgrade changed things. Sorry HassOS has been regularly upgraded and I am on 2022.3.1.
I have to update my previous posting to reflect that I forgot to add that you need to include a “container port” in UNRAID so that this app can communicate with the device. In my case, I am using 4199 instead of the default and yours needs to match how you configured the gateway.
Hmm I have it set up the same way, I am not sure why it’s not working. When I click on the docker log icon in Unraid, it’s just completely empty even when it’s running. No errors but also nothing else. Using MQTT Explorer I don’t see any new topic being created. I have a bunch of stuff running using MQTT (zigbee2MQTT, zwave2MQTT, Frigate, etc) so I know MQTT is setup properly.
