Edit an imported blueprint
I am trying to adapt what seems to be a rather wonderful blueprint from bbbenji - a water leak detection and notification automation.
The only change I want to make is to have multiple devices notified, instead of the one only in the blueprint.
Still not sure I have got my head around editing imported blueprints, but what I have done is copied blueprint config after running it and copying the trace, and then created a new automation. I am not even sure this is valid method, but when I try to save the new automation, I get an error.
I did set up a notification group in my config.yaml file - and this may or may not be part of the problem:
notify:
  - name: mobiles_plus_alexas
    platform: group
    services:
      - service: mobile_app_one
      - service: mobile_app_two
      - service: alexa_media
            - media_player.blah1_echo_dot
            - media_player.blah2_echo_dot
            - media_player.blah3_echo_dot
            - media_player.blah1_echo_show
            - media_player.blah4_echo_dot
            - media_player.blah5_echo_dot
            type: tts
The automation I have “recreated” is as follows:
  - event_data: {}
    event_type: state_changed
    platform: event
condition:
  - condition: template
    value_template: '{{ trigger.event.data.new_state.attributes.device_class == "moisture" }}'
    value_template: '{{ trigger.event.data.new_state.state == "on" }}'
  - service: notify.mobiles_plus_alexas
    message: >-
    {{ trigger.event.data.new_state.attributes.friendly_name }} has detected a
    leak.
    title: Leak detected!
mode: single
alias: Leak detection & multiple notifications
The error I get when I try to save it is:
Message malformed: extra keys not allowed @ data['rigger']
Can anyone tell me what I am doing wrong - possibly multiple things ?
    message: >-
    leak.
Your indentation under message is wrong.
    message: >-
    leak.
Other, hopefully, helpful things.
  1. Blueprints are stored in /config/blueprints under a folder for the author. You can directly edit them there.
  2. I have no idea if the group will work, but a script surely would.
