Hello to the round! I have only recently started using Home Assistant, but have some experience with FHEM from the past. With Home Assistant I would like to visualize the data of my solar system. This I have also managed very quickly and am already quite satisfied. The solar system runs since 20.07.22. Home Assistant I have but only since the end of September. All data between commissioning and start of Home Assistant I had manually written in a table. Is there a possibility to add the old data in Home-Assistent in the form of logbook entries or to edit incorrectly entered data so that they are correctly observed in the statistics?
Thank you very much for the support.
Saturus78
Translated with DeepL Translate: The world's most accurate translator (free version)
