I updated to OS 9.0 and now my z-wave stick will not power up and cannot be found by the OS. The dev spot just does not appear to be there anymore. My config.txt is unchanged and a backup restoration didn’t revert the OS.
Can I revert back to 8.5 somehow? Without the zwave not much in my house works…
EDIT:
It now sees the zwave device, but the OS will not integrate any of the values
EDIT2:
I updated the post title to more accurately reflect my current issue, that BLE seems to have been broken since the update (zwave is fixed, this is my last lingering issue)
Core Logs:
2022-09-15 09:38:41.309 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-09-15 09:38:41.315 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-09-15 09:38:41.321 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration var which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-09-15 09:38:41.324 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-09-15 09:38:47.623 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-09-15 09:38:47.784 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=98 from 2022-09-15 16:05:58.324277)
2022-09-15 09:39:00.207 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_zwavejs2mqtt: Can't read stats from addon_a0d7b954_zwavejs2mqtt: Expecting value: line 1 column 1 (char 0)
2022-09-15 09:39:23.187 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Failed to connect: Cannot connect to host a0d7b954-zwavejs2mqtt:3000 ssl:default [Connect call failed ('172.30.33.0', 3000)]; Retrying in background
2022-09-15 09:39:23.213 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2022-09-15 09:39:23.215 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2022-09-15 09:39:23.217 WARNING (MainThread) [homeassistant.setup] Setup of automation is taking over 10 seconds.
2022-09-15 09:39:30.605 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Bathroom Heater HS100(US)' for tplink integration not ready yet: Unable to connect to the device: 192.168.1.8: [Errno 111] Connect call failed ('192.168.1.8', 9999); Retrying in background
2022-09-15 09:39:31.399 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Bed Ice HS100(US)' for tplink integration not ready yet: Unable to connect to the device: 192.168.1.14: [Errno 113] Connect call failed ('192.168.1.14', 9999); Retrying in background
2022-09-15 09:40:10.110 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.living_room_temp_7_day_mean is changing, got multiple {'°F/min', None}, generation of long term statistics will be suppressed unless the unit is stable and matches the unit of already compiled statistics (°F/min). Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
2022-09-15 09:40:10.118 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.living_room_temp_7_day_std_dev is changing, got multiple {'°F/min', None}, generation of long term statistics will be suppressed unless the unit is stable and matches the unit of already compiled statistics (°F/min). Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
2022-09-15 09:40:43.653 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Failed to connect: Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed ('172.30.33.1', 3000)]; Retrying in background
2022-09-15 09:44:28.423 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Failed to connect: Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed ('172.30.33.1', 3000)]; Retrying in background
2022-09-15 09:48:55.271 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (E4:5F:01:D8:B0:7E): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2022-09-15 09:50:53.245 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (E4:5F:01:D8:B0:7E): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
Supervisor:
22-09-15 09:38:32 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/zwavejs2mqtt/aarch64 with version 0.46.1
22-09-15 09:38:32 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ghcr.io/esphome/esphome-hassio-aarch64 with version 2022.8.3
22-09-15 09:38:32 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-zwave_js with version 0.1.70
22-09-15 09:38:32 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mariadb with version 2.5.1
22-09-15 09:38:33 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Z-Wave JS to MQTT is failed, restarting...
22-09-15 09:38:33 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/ssh/aarch64 with version 12.0.2
22-09-15 09:38:33 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.4.1
22-09-15 09:38:33 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/glances/aarch64 with version 0.16.0
22-09-15 09:38:33 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/vscode/aarch64 with version 5.3.0
22-09-15 09:38:33 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon ESPHome is failed, restarting...
22-09-15 09:38:33 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:38:33 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_5c53de3b_esphome application
22-09-15 09:38:33 INFO (MainThread) [supervisor.backups.manager] Found 10 backup files
22-09-15 09:38:33 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
22-09-15 09:38:33 INFO (MainThread) [supervisor.ingress] Loaded 3 ingress sessions
22-09-15 09:38:33 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-09-15 09:38:33 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-09-15 09:38:33 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-09-15 09:38:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-15 09:38:33 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-09-15 09:38:33 INFO (MainThread) [__main__] Running Supervisor
22-09-15 09:38:33 INFO (MainThread) [supervisor.os.manager] Rauc: B - marked slot kernel.1 as good
22-09-15 09:38:33 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-09-15 09:38:33 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 1 add-ons
22-09-15 09:38:33 ERROR (MainThread) [supervisor.utils] Can't execute run while a task is in progress
22-09-15 09:38:33 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on ghcr.io/esphome/esphome-hassio-aarch64 with version 2022.8.3
22-09-15 09:38:34 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwavejs2mqtt/aarch64 with version 0.46.1
22-09-15 09:38:35 ERROR (MainThread) [supervisor.api.middleware.security] Invalid token for access /addons/self/info
22-09-15 09:38:37 ERROR (MainThread) [supervisor.api.middleware.security] Invalid token for access /info
22-09-15 09:38:38 ERROR (MainThread) [supervisor.api.middleware.security] Invalid token for access /addons/self/options/config
22-09-15 09:38:38 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 2 add-ons
22-09-15 09:38:40 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-zwave_js with version 0.1.70
22-09-15 09:38:42 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/vscode/aarch64 with version 5.3.0
22-09-15 09:38:46 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_zwave_js
22-09-15 09:38:47 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-09-15 09:38:47 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 1 add-ons
22-09-15 09:38:47 WARNING (MainThread) [supervisor.addons.addon] 5c53de3b_esphome is already running!
22-09-15 09:38:48 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
22-09-15 09:38:48 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-15 09:38:48 INFO (MainThread) [supervisor.discovery] Sending discovery to Home Assistant zwave_js from core_zwave_js
22-09-15 09:38:50 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-09-15 09:38:52 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-09-15 09:38:52 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-09-15 09:38:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-09-15 09:38:54 INFO (MainThread) [supervisor.host.services] Updating service information
22-09-15 09:38:54 INFO (MainThread) [supervisor.host.network] Updating local network information
22-09-15 09:38:55 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-09-15 09:38:55 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-09-15 09:38:55 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-09-15 09:38:55 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-09-15 09:38:55 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-09-15 09:38:55 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-09-15 09:38:56 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-09-15 09:38:56 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-09-15 09:38:58 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-15 09:38:58 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-09-15 09:38:58 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-09-15 09:38:58 INFO (MainThread) [supervisor.store] Loading add-ons from store: 140 all - 0 new - 0 remove
22-09-15 09:39:00 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Z-Wave JS to MQTT is stopped, restarting...
22-09-15 09:39:00 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:39:00 ERROR (SyncWorker_7) [supervisor.docker.interface] Can't read stats from addon_a0d7b954_zwavejs2mqtt: Expecting value: line 1 column 1 (char 0)
22-09-15 09:39:01 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwavejs2mqtt/aarch64 with version 0.46.1
22-09-15 09:39:33 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-09-15 09:40:43 INFO (SyncWorker_2) [supervisor.docker.interface] Stopping addon_core_zwave_js application
22-09-15 09:40:48 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_core_zwave_js application
22-09-15 09:40:56 INFO (SyncWorker_3) [supervisor.docker.interface] Stopping addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:41:01 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:41:02 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwavejs2mqtt/aarch64 with version 0.46.1
22-09-15 09:43:26 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:43:30 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:43:31 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwavejs2mqtt/aarch64 with version 0.46.1
22-09-15 09:46:45 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-zwave_js with version 0.1.70
22-09-15 09:46:48 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_zwave_js
22-09-15 09:48:48 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping addon_core_zwave_js application
22-09-15 09:48:54 INFO (SyncWorker_4) [supervisor.docker.interface] Stopping addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:48:54 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_core_zwave_js application
22-09-15 09:48:55 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-zwave_js with version 0.1.70
22-09-15 09:48:58 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_zwave_js
22-09-15 09:48:59 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_a0d7b954_zwavejs2mqtt application
22-09-15 09:49:00 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwavejs2mqtt/aarch64 with version 0.46.1
22-09-15 09:49:33 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping addon_core_zwave_js application
22-09-15 09:49:37 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_core_zwave_js application
