Hi! I’ve integrated my sonoff mini device in to Home Assistant, but now I see I have made a mistake in my tasmota settings. So I want to change this settings but I can’t come in to the Tasmota settings dashboard.
does anyone know how to fix this?
Install the tasmoadmin add-on
or you should still be able to go directly to the devices ip address and edit the settings there. is that not possible?
but tasmoadmin is very convenient.
That’s why I recommended tasmoadmin, you can search for your tasmota devices.
When I installed tasmoadmin, it has the error that it can’t find any devices. Also I can’t go to the devices directly with the IP-Adres.
Can you ping it ?
Yes, and in my router I also see it. In my Home Assistant I can use it, but not as I want to use it, so that is why I wanna change the settings.
You can try to reboot it by publishing cmnd/%topic%/restart, topic being the name of your mini
Do I have to do this command in my command prompt?
No. In HA under developer tools, MQTT, publish.
