I am trying to edit the file for the first time and when I try to save I get the following error:
Error opening file ‘/usr/share/hassio/homeassistant/configuration.yaml’: Permission denied
The file on disk may now be truncated!
What I did so far:
Give the file write permission via sudo chmod 664 /usr/share/hassio/homeassistant/configuration.yaml
Attempt to add my user, pi, to the sudo group via: sudo usermod -aG sudo pi
I am still not able to edit the file and now when I open it, it appears empty. So I somehow managed to delete its contents apparently, but still can’t save it.
What am I doing wrong here?
Edit: Now I am also getting the “inode / x-corrupted” error.
Edit 2: sudo chown pi /usr/share/hassio/homeassistant/configuration.yaml also didn’t work.
@GaryK thx, samba did the trick! In the process I also learned how to edit files via command line, which also works great, in comparison with the GUI file explorer. For some reason, when I use the explorer and a coding editor, it just opens an empty file. The file type says something about node / x-corrupted and I get a bunch of permission errors, trying to save the file. Guess the command line is actually the better tool here.
