I’m new to HA, and first time editing configuration.yaml.
I applied all available updates.
- Core 2024.6.3
- Supervisor 2024.06.0
- Operating System 12.3
- Frontend 20240610.1
I’m following this article specifically the post by @Simon_Bunn with “configuration.yaml for a cyberpower UPS and the entities card setup.”
I have not yet needed to edit configuration.yaml, so I searched and found this article. Which said: If you are unsure which option to choose, install the file editor add-on.
It says “Once you have the add-on installed, you can edit files within your /config directory.”
I completed the installation of Current version: 5.8.0, and clicked Open in Web UI.
I clicked the “Browse Filesystem” icon at the upper left.
It shows the current directory as /homeassistant, and lists about a dozen files, including configuration.yaml.
Next to the /homeassistant path, there is a left arrow. Thinking it will take me up a level to then select the “/config” directory, I click it. Nothing happens.
I can open /homeassistant/configuration.yaml, but I’m not sure that is the correct one. What is my configuration directory? Does it move?
I read “To look up the path to your configuration directory, go to Settings > System > Repairs.”
That only shows me “There are currently no repairs available”, not the dialog shown on this page. The link to System Information is not there. I thought it might be under “About”, but it is not there either.
Can anyone point me to current documentation on editing configuration.yaml?
Edit: I looked from the terminal and it appears that both /config and /homeassistant contain configuration.yaml:
Welcome to the Home Assistant command line.
OS Version: Home Assistant OS 12.3
Home Assistant Core: 2024.6.3
Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357
[core-ssh ~]$ ls
addon_configs addons backup config homeassistant media share ssl
[core-ssh ~]$ cd config
[core-ssh config]$ ls
automations.yaml deps home-assistant.log.fault home-assistant_v2.db-wal secrets.yaml zigbee.db-shm
blueprints home-assistant.log home-assistant_v2.db scenes.yaml tts zigbee.db-wal
configuration.yaml home-assistant.log.1 home-assistant_v2.db-shm scripts.yaml zigbee.db
[core-ssh config]$ cd /
[core-ssh /]$ cd homeassistant/
[core-ssh homeassistant]$ ls
