I am very new to HA and have gotten so far as to getting Mushroom and Mushroom Theme.
I wanted to modify the cards a bit and tried doing as the Mushroom information page said, but I can’t get the changes to work.
I have tried editing the mushroom.yaml file, but nothing I do makes the cards change. I have tried refreshing, restarting HA and still nothing.
The thing I wanted to edit was the radius on the corners of the cards so I edited this:
Yes, I have added this to the config yaml.
I also tried reloading themes after changing the mushroom.yaml file. Nothing changes in my cards on my dashboard.
I have selected the Mushroom theme in my user settings, yes.
And my Mushroom theme file looks like this now.
Am I wrong to change the border-radius under Cards to make them rounder?
I have tried changing both “mush-control-border-radius” and “ha-card-border-radius”. None of them do what I am looking for, making the cards rounder.
Sorry if I am misunderstanding, but is this wrong? Should not making this number bigger make them rounder?
I have reloaded themes from Developer Tools each time also.
Yes, I have restarted it multiple times. I can try again.
But to be sure, which of the lines should I edit to make my cards rounder? The two I mentioned?
Hi @pedolsky .
How can I modify the square theme?
Following the above posts I have modified successfully the colors of the mushroom theme, but it seems the same rules are not working on the mushroom square theme…
