trying to use Home Assistant for the firs time. i am trying to install the Water furnace Integration but no success. instructions say add this (
waterfurnace:
username: YOUR_USERNAME
password: YOUR_PASSWORD) to the config yaml and i did but no success what am i missing?
Spacing is important in yaml. Did you space it correctly?
i copied and pasted sorry for sounding stupid but i am totally new to this
Hi, welcome to the forum!
Have you edited your configuration.yaml file and added those lines while respecting spacing/indents?
Make sure your credentials (user & password) are correct.
You have to restart your HA to make the changes work. (be sure to check your configuration first against errors)
restarting worked thank you
Good you got it solved!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so this can be useful to other users as well and prevents that someone else steps in and still tries to help you.
