My system uses GE (Jasco) zwave dimmers that have different model numbers, some of them allow for long dim-transitions and others do not. After researching it appears that the key difference lies in the dimming duration
value under COMMAND_CLASS_SWITCH_MULTILEVEL
. I’m hoping to ‘unlock’ this functionality by editing the zwcfg_xxxx.xml file.
I’m writing this post to:
- Verify that you can enable this functionality through altering the zwcfg file
- Verify that my edits are correct
- Verify that the order of operations will achieve desired result
I have read through this previous post and am using it for reference (link)
#1)
Zwcfg snip of device with long-dimming
<Node id="12" name="" location="" basic="4" generic="17" specific="1" roletype="5" devicetype="1536" nodetype="0" type="Multilevel Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="63" name="Jasco Products">
<Product type="4944" id="3038" name="14294 In-Wall Smart Dimmer" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="38">
<Instance index="1" />
</CommandClass>
<CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="2" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="user" instance="1" index="1" label="Bright" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="user" instance="1" index="2" label="Dim" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="bool" genre="system" instance="1" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="byte" genre="system" instance="1" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
#Adding comment for post clarity - see line below
<Value type="byte" genre="system" instance="1" index="5" label="Dimming Duration" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255" />
</CommandClass>
Zwcfg snip of device without long-dimming
<Node id="9" name="" location="" basic="4" generic="17" specific="1" type="Multilevel Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Product type="4944" id="3031" name="12724 3-Way Dimmer Switch" />
</Manufacturer>
<CommandClasses>
</CommandClass>
<CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="1" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="99" />
# Missing line for "Dimming Duration"
</CommandClass>
The second device is missing the “Dimming Duration” value under COMMAND_CLASS_SWITCH_MULTILEVEL
#2)
Is the process as easy as pasting the line below into the zwcfg file? (@ # Missing line for “Dimming Duration”)
#3)
Assuming #1 and #2 are correct, it is my understanding that the appropriate order would be:
- Stop zwave network via the configuration gui
- Make edits outlined in #2 above to the zwcfg_xxxx.xml file
- Start zwave network
- restart
