the documentation only describes the configuration of ser2net.conf. Does anyone know what the entry in ser2net.yaml should look like?
best regards andreas
I use the following configuration for the Hichi IR sensor mounted on the Iskra MT681:
connection: &hichi_ir
accepter: tcp,1234
enable: on
options:
kickolduser: true
connector: serialdev,
/dev/ttyUSB0,
9600n81,local
1234
→ port
9600
→ bit rate
n
→ no parity bit
8
→ 8 data bits
1
→ 1 stop bit
Restart the ser2net
service (sudo service ser2net restart
), and you should then be able to check that data is forwarded to the port by probing it with telnet (telnet <YOUR_IP_ADDRESS> 1234
You can then use the following EDL21 integration config in your configuration.yaml
- platform: edl21
serial_port: socket://<YOUR_IP_ADDRESS>:1234
