Same, still not working today. Thought it was a transient API problem at the Efergy end so ignored it for a couple of days, but sadly its still not working.
I am getting realtime readings through but daily cost & consumption are zero.
Had a look on the efergy dashboard, seems there’s no consumption history showing for today, although there is for yesterday.
Still not working today, but I did notice this API error, are you seeing same @91JJ ?
Logger: homeassistant.components.sensor
Source: components/efergy/sensor.py:167
Integration: Sensor (documentation, issues)
First occurred: 24 October 2022 at 13:10:50 (1 occurrences)
Last logged: 24 October 2022 at 13:10:50
efergy: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 493, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 703, in async_device_update
await task
File "/usr/src/homeassistant/homeassistant/components/efergy/sensor.py", line 167, in async_update
data = await self.api.async_get_reading(
File "/usr/local/lib/python3.10/site-packages/pyefergy/__init__.py", line 203, in async_get_reading
_data = await self._async_req(command, params=params)
File "/usr/local/lib/python3.10/site-packages/pyefergy/__init__.py", line 150, in _async_req
raise exceptions.APICallLimit(
pyefergy.exceptions.APICallLimit: API key
I have problems with Efergy since almost one week ago with data unavailable/loss on both HA and Efergy dashboard.
At this moment I have zero consumption on HA and Efergy dashboard but yesterday morning it was like everything was working fine, I think Efergy has big troubles with their systems and that is the reason why HA integration shows errors.
Same has happened to me. Was power cycling my hub trying to get it to work then checked on Twitter to see others were having issues. Has been stable for me for years,
I hardly use it now due to have a smart meter and 3rd party in house display with local MQTT.
I have the same issues and have contacted support. This was their reply
Thanks for getting in touch - we’ve got an issue with the inbound queues that is affecting the data. Please be reassured that your data is not lost but taking a while to be processed.
The team are working on it but the resolution can’t be top priority. As you may know we retired the product back in 2017 and although we continue to provide support, we don’t have the resources to prioritise sorting out issues if they arise.
The good news is that we know that there is an issue, it is being monitored and your data is not being lost. The team hope to get it resolved over the next fortnight. Please bear with us in the meantime.
The main issue to me seem to be that The product was retired in 2017 and as such resource allocation to fix it is minimal.
I guess that it might be time to move onto a new product/tool/device but what? This device was inexpensive and not technically complicated.
Yes I did look at that but was hoping for a solution where I did not have to get the soldering iron out.
I have an older Enphase Solar system with an older Envoy.
I thought about upgrading the Envoy to an Envoy S Metered but a few things came to mind.
Cost? Firstly of device and then install by electrician
Interface with HA
Anyone have experience with the Pulse system and it’s accuracy or the Enphase Envoy S Metered?
I have been using Efergy since 2015, almost never had any problems, but now like everyone else my HA is not receiving data, the Efergy dashboard is still not working. As far as I can see the service is going to stop working forever, if you go to the Efergy website to buy a new kit there are no new kits, they are out of stock for days. It makes you think that very probably the life of this company is in the last days. They have not informed in any media (Web, Twitter, etc…) of the status of the problem, this means something in any company… the ship is sinking!
I found a solution (probably a workaround) on another discussion but you need to run a local DNS server on your network.
You just have to add an “A Record” in your DNS for *.h2.sensornet.info and point it to 154.51.148.15.
On internet it points to 154.51.163.16
I did it and I’m having back the readings on the Efergy dashboard and HA.
