Efergy Engage CT Clamp Capture with ESP Home
Recently Efergy decommissioned their Engage Hub which made a lot of devices redundant (more info HERE)… So this package is aimed at capturing the 433MHz signals and decoding them to give you the actual readings.
(pictures for illustration only)
Other similar projects have been accomplished by others but aren’t similar to this…
  • Capture the data from the Efergy Hub and redirect to your own server
  • Build your own ESP Home Energy Monitor.
This is purely to use ESP Home to capture and decode the data from the Efergy transmitter and publish to Home Assistant to be used for Energy Tracking.
Entities:
  • sensor.efergy_current
  • sensor.efergy_power_usage
  • sensor.efergy_energy_usage
  • sensor.efergy_interval
  • binary_sensor.efergy_pairing_mode
  • sensor.efergy_tx_id
  • sensor.efergy_battery_state
Hardware Required:
  • ESP32 board running ESPHome
  • CC1101 433 MHz module
  • Efergy CT Clamp Transmitter
Github: GitHub - 91JJ/Efergy-CT-Clamp-Capture-for-ESP-Home: Repurpose Efergy CT clamps with ESPHome for easy, low-cost energy monitoring in Home Assistant. · GitHub
Minimal YAML:
substitutions:
  device_name: efergy-sensor
  friendly_name: Efergy Energy Monitor
  board_type: esp32dev
  wifi_ssid: !secret wifi_ssid
  wifi_password: !secret wifi_password
  fallback_ap_password: !secret fallback_ap_password
  mains_voltage: "230.0"
  preferred_tx_id: "auto"
external_components:
  - source: github://91JJ/Efergy-CT-Clamp-Capture-for-ESP-Home@main
    components: [efergy_cc1101]
    refresh: 0s
spi:
  clk_pin: ${pin_cc1101_sck}
  miso_pin: ${pin_cc1101_miso}
  mosi_pin: ${pin_cc1101_mosi}
efergy_cc1101:
  spi_id: efergy_spi_bus
  mains_voltage: ${mains_voltage}
  preferred_tx_id: "${preferred_tx_id}"
  publish_raw_bytes: ${publish_raw_bytes}
  cs_pin: ${pin_cc1101_csn}
  gdo0_pin: ${pin_cc1101_gdo0}
  gdo2_pin: ${pin_cc1101_gdo2}
  current:
  power:
    name: "${friendly_name} Power Usage"
  interval:
    name: "${friendly_name} Interval"
  pairing:
    name: "${friendly_name} Pairing Mode"
  tx_id:
    name: "${friendly_name} TX ID"
  battery_state:
    name: "${friendly_name} Battery State"
  raw_bytes:
    name: "${friendly_name} Raw Bytes"
    disabled_by_default: true
  - platform: copy
    source_id: efergy_power_w
    internal: true
    unit_of_measurement: "kW"
    accuracy_decimals: 4
    filters:
      - multiply: 0.001
  - platform: integration
    name: "${friendly_name} Energy Usage"
    sensor: efergy_power_kw
    unit_of_measurement: "kWh"
    device_class: energy
    state_class: total_increasing
    time_unit: h
    restore: true
    accuracy_decimals: 3
Locking TX ID:
I’ve noticed the code isn’t great at finding & locking the TX id… However, if you watch the logs you should be able to identify it yourself and change the config from auto to your TX ID.
NOTE: I'm a novice with Github, FSK & ESP Home so any improvements are welcomed.
Is this a follow on from Energy Tracking with ESP32 + CT Clamp Sensor from an Efergy elite 1.0R and other threads?
I believe this is slightly different…
You only need an ESP32 & CC1101 to capture the data & decode from the official Efergy CT Clamp.
Background: Efergy recently turned off their servers so the smart hubs become redundant… This is a way to re-use some of the old kit.
