Eriobis
(Simon Benoit)
January 6, 2020, 9:06pm
1
I am new to Home assistant, wanted to convert my smart plug to ESPHome plug but I didn’t find any “premade” configuration for it.
Here the amazon link if you want to buy them :
https://www.amazon.com/EFUN-Motoring-Required-Appliance-Assistant/dp/B07DCJ7TDR?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B07DCJ7TDR
It’s based on a ESP8266-S3 ( which is the one made for slotted PCB I believe ).
After reading this page :
Quindor has excellent guide for using $10 WiFi plugs for energy monitoring over on his blog intermit.tech . I ordered 6 of them from Amazon UK but what I received was a slightly different model, the Teckin SP23. These unit run Tuya and need to be converted, but he details the process very well.
However, after flashing them with ESPHome, they barely worked so obviously the internal configuration has changed. After a bit of researh, I got almost everything working except for the red LED, so perha…
I have tweaked it to add the ESP blue led and the proper red led integration.
Enjoy
#Configuration for EFUN SH3331W Smart Plug
substitutions:
plug_name: esun_plug
# Higher value gives lower watt readout
current_res: "0.00221"
# Lower value gives lower voltage readout
voltage_div: "940"
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "SSID"
password: "PASS"
ap:
ssid: "Esun Plug Fallback Hotspot"
password: "1J01nevV4P5p"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "PASS"
ota:
password: "PASS"
time:
- platform: homeassistant
binary_sensor:
- platform: gpio
pin:
number: GPIO13
inverted: True
on_press:
then:
- switch.toggle: "${plug_name}_Relay"
- switch.toggle: "${plug_name}_LED_Blue"
switch:
- platform: gpio
pin: GPIO15
restore_mode: ALWAYS_ON
- platform: gpio
pin: GPIO2
inverted: True
- platform: gpio
pin: GPIO4
inverted: True
- platform: gpio
pin: GPIO0
inverted: True
restore_mode: ALWAYS_OFF
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO05
cf1_pin: GPIO14
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: A
voltage:
unit_of_measurement: V
power:
unit_of_measurement: W
change_mode_every: 8
update_interval: 10s
- platform: total_daily_energy
name: "${plug_name}_Total Daily Energy"
power_id: "${plug_name}_Wattage"
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
# Extra sensor to keep track of plug uptime
- platform: uptime
danhiking
(Daniel)
December 28, 2020, 1:22am
2
Thanks for the config! Replying here in Dec 2020 to say Tuya convert still works on some recently bought SH331-s from Amazon.
Any suggestions how best to calibrate a device when given known current and power are measured at multiple points?
Eriobis
(Simon Benoit)
December 28, 2020, 8:53pm
3
I only see the config for a gain (multiplier ) in the current setup.
I don’t know where this value comes from. Do you have data on the current curve ?
( At this moment the plug is used to monitor the christmas tree, so the current consumption isn’t that important )
For reference if you need to hack the plug and remove the whole back :
danhiking
(Daniel)
December 29, 2020, 1:37am
4
I’m trying to calibrate with a 30W soldering iron that has a rock-solid 30W resistive load that produces a power factor of 1.00.
Yet the numbers coming out the SH331 don’t seem to make sense!
amperage: 0.145 A
voltage: 133 V
wattage: 33.9 W
But 133 V * 0.145 A = 19.3 VA, which is way off the wattage for a resistive load. Any idea what could be going on?
By adjusting current_resistor and voltage_divider I could calibrate two of the three quantities, but not all three. The power and voltage (or current) are computed separately: https://github.com/esphome/esphome/blob/ac15ce576b1c22e59a7186014de0202e79de959b/esphome/components/hlw8012/hlw8012.cpp#L55
Could there be anything else different in these chips that might need tweaking?
Note: The HLW8012 library that Esphome links to has apparently separate multipliers for the three quantities: https://github.com/xoseperez/hlw8012/blob/2dace562c339e77a2889446d461e8e56048fe634/src/HLW8012.cpp#L153
Clayton
(Clayton Ross)
December 4, 2021, 4:45am
5
hello all, I have 8 of these I was able to tuya convert, trying to get this config on them but I am getting errors. i am wondering of something changed in esp syntax or maybe it’s just me , I could not YAML my way out of a paper sack
I am getting Dashes are not supported in IDs,
thanks for the help
full config
substitutions:
plug_name: efun-01
voltage_div: "940"
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "ClanOfRoss"
password: "megahugeboners"
ap:
ssid: "Efun-01 Fallback Hotspot"
password: "3doors3whores"
captive_portal:
# Enable logging
logger:
api:
password: "PASS"
ota:
password: "PASS"
time:
binary_sensor:
- platform: gpio
pin:
number: GPIO13
inverted: True
on_press:
then:
switch:
- platform: gpio
pin: GPIO15
- platform: gpio
pin: GPIO2
inverted: True
- platform: gpio
pin: GPIO4
inverted: True
- platform: gpio
pin: GPIO0
inverted: True
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO05
cf1_pin: GPIO14
current:
voltage:
power:
filters:
- multiply: 0.001
- platform: uptime
danhiking
(Daniel)
January 20, 2022, 6:04pm
6
Hi Clayton,
FWIW I haven’t changed the YAML config in ~ year, and still seems to be working. Just to confirm that things are still working, I include my yaml here for reference:
# EFUN SH331
substitutions:
plug_name: efun_01
voltage_div: "940"
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Efun Fallback Hotspot"
password: !secret fallback_password
captive_portal:
# Enable logging
logger:
api:
ota:
time:
binary_sensor:
- platform: gpio
pin:
number: GPIO13
inverted: True
on_press:
then:
switch:
- platform: gpio
pin: GPIO15
- platform: gpio
pin: GPIO2
inverted: True
- platform: gpio
pin: GPIO4
inverted: True
- platform: gpio
pin: GPIO0
inverted: True
web_server:
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO05
cf1_pin: GPIO14
current:
voltage:
power:
filters:
- multiply: 0.001
- platform: uptime
