I just bought 10 bulbs connect.z with Bluetooth and Zigbee Support. Unfortunate, I can’t reset the bulbs and integrate them with my Home Assistent system like I have been doing that with other Zigbee devices as well. I don’t want using the app or the remote control, I only need the fully ZigBee Suppport like it is stated on the outer packaging of the bulbs (G80 E27 - Zigbee & Bluetooth Support).
So I’m seeking our here for a a way I can reset the bulbs (e.g. 4x Powerswitch on/of for 5 seconds each)
to discover them afterwards with my Home Assistent/ZigBee Discovery Modus?
That what would be an extremely enlightenment and relief since I want to re-place about 60-70 bulbs in favor of my Home Assistent.
Might anyone here can share any experience with Eglo Smart Bulbs?
Did you got your bulbs to work with the homeassistant native zigbee integration (ZHA)?
I am looking at buying some led panels from eglo that also mention the connect.z …
I am wondering it they would work since I cannot find much information online.
I don’t know if you’re still looking for an answer, but for anyone else who finds this thread: Yes, with the on/off sequence as described by @koying the light got added to HA (at least in my case it did )
Hello
Thanks a lot for the information.
I haven’t bought these bulbs yet but there is a lot of offer in local stores and with the confirmation that they work with HA I probably will
For anybody having issues to join the Eglo Connect Z into ZHA: Connect with the “AwoX HomeControl” App via Bluetooth, update the firmware, reset it using the sequence mentioned above - et voilà, it pairs successfully.
I tried resetting & pairing 15-20 times - without any success - then I found out, it also has a Bluetooth connection… yay. Right after updating and resetting, it worked instantly.
I can’t find detailed description of how to add my eglo connect z lights to the Home Assistant.
Could you explain in a few steps how to do it and what tools are needed?
I already have a few devices in HA, but I’m a relative beginner on this topic.
I can confirm that my Eglo bathroom ceiling light works with zigbee2mqtt where it is recognised as AwoX 33955.
I had many issues with that light as it doesn’t report proactively its state as online when it gets connected to electricity. It is also not as responsive as other lights and it can get overwhelmed if I change its state in rapid succession. However it works well with HACS adaptive lighting. Overall I couldn’t find better light for bathroom with ip44 and for its price.
Works as described. Follow the rythm in the video and you can add and use the connect.z bulb in home-assistant. No need for an extra remote or app on your phone.
Thank you koying.
Works as described above, update firmware using the Awox app, then reset(like in the video) and immediately after permit join to the zigbee network. Thank’s a lot !
I just got the same remote and this thread helped me a bit by piecing things together. I got it paired but it definitely wasn’t easy - it took me some trial and error but here’s the process that I think got it working:
install the smartphone app
set the remote in pairing mode with [on] + [blue] simultaneously for 3 seconds
upgrade the firmware with the app
factory reset the remote with [on] + [colored wheel] for 3 seconds
set Z2M in pairing mode
set the remote in pairing mode again
… profit?
It took me many tries where the remote got detected every time, but the interviewing always failed. Eventyally, after many factory resets and and many re-pairings it got interviewed and now it’s working and sending every command except, strangely, the button “3”. Better than nothing though!
I am having this very weird issue with these lights. When I add one or more to the ZHA network other lights become unavailable. I did a Factory reset and clean install with the Home Assistant Yellow, added 56 devices and after I have added one of these lights a few hours later two other lights (Philips Hue) became unavailable. Both of these lights are in the middle of the ZHA network so out of range is absolutely impossible.
Sounds very weird indeed.
I have a zlzb-06m coordinator, and 124 devices connected to it at the moment.
If I counted correctly 69 of them are philips Hue and I don’t have an issue with devices becoming unavailabe except for the eglo light which is not connectded.
My coordinator is connected through PoE and is configured as a zigbee coordinator only.
If I recall correctly the home assistant yellow use the same antenna for zigbee and something else (matter over thread or bluetooth or both) That might affect your zigbee performance if active.
Check how many devices are connected directly to your coordinator. Depending on the zigbee chip, those direct connections can be as low as 32. Anything above what your chip supports and you need to connect your other devices via routers.
If you have 56 devices, chances are most of those are connected directly and that you’ve hit this limitation, causing other devices to drop out.
