Hi guys,
I am having issues updating my DIY EHMTXv2 Display, it is running on 2024.10.3 but I can not compile higher versions…
my yaml:
substitutions:
devicename: display
friendly_name: LED Matrix Display
board: esp32dev
ldr_pin: GPIO36
matrix_pin: GPIO14
esphome:
comment: "EHMTXv2 from LuBeDa"
project:
switch:
name: "Auto-Adjust Brightness"
icon: mdi:brightness-auto
restore_mode: RESTORE_DEFAULT_ON
lambda: |-
if (id(aab_enable)) {
return true;
} else {
return false;
turn_on_action:
lambda: |-
id(aab_enable) = true;
turn_off_action:
lambda: |-
id(aab_enable) = false;
icon: "mdi:power"
restore_mode: ALWAYS_ON
lambda: |-
return id(rgb8x32)->show_display;
turn_on_action:
lambda: |-
id(rgb8x32)->set_display_on();
turn_off_action:
lambda: |-
id(rgb8x32)->set_display_off();
number:
name: "$devicename brightness"
min_value: 5
max_value: 255
step: 1
lambda: |-
return id(rgb8x32)->get_brightness();
set_action:
lambda: |-
id(rgb8x32)->set_brightness(x);
globals:
# aab = auto-adjustable brightness
- id: aab_enable
type: "bool"
restore_value: true
initial_value: "true"
- id: aab_add
type: int
initial_value: '10'
- id: aab_max
type: int
initial_value: '220'
- id: aab_min
type: int
initial_value: '20'
external_components:
- source:
type: git
url: https://github.com/lubeda/EspHoMaTriXv2
ref: main
refresh: 60s
components: [ ehmtxv2 ]
esp32:
board: esp32dev
font:
# Font included in this folder
- file: fonts/CalciumThin.ttf
glyphs: >-
!?"%()+*=,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnÖÄÜöäüopqrstuvwxyz@<>ߧ€/
glyphs: |
- file: fonts/CalciumThin.ttff
glyphs: |
! "#$%&'()*+,-./0123456789:APMTapmt
# - file: fonts/monobit.ttf
# id: monobit
# size: 16
# glyphs: |
# ! "#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz°
animation:
- id: animation_black
file: "black.gif"
image:
- id: image_black
file: "black.gif"
binary_sensor:
- platform: status
logger:
level: WARN
api:
encryption:
key: "tuPXWWxxJ3APyDVlkLvYTz392yyC5oNfN9SqFQ5oUtA="
- platform: adc
name: "$devicename Illuminance"
pin: $ldr_pin
update_interval: 2s
attenuation: auto
unit_of_measurement: lx
device_class: illuminance
accuracy_decimals: 0
filters:
- lambda: |-
return ((x / 10000.0) * 2000000.0 + 25) ;
on_value:
then:
- lambda: |-
if ( id(aab_enable) ) {
int n = x / 4 + id(aab_add); // new_value
if (n > id(aab_max)) n = id(aab_max);
if (n < id(aab_min)) n = id(aab_min);
int c = id(rgb8x32)->get_brightness(); // current value
c = c>0?c:1 ;
int d = (n - c) * 100 / c; // diff in %
if ( abs(d) > 2 ) id(rgb8x32)->set_brightness(n);
ota:
- platform: esphome
password: "af62ead709ad8aa53cacd241602a3def"
wifi:
ssid: !secret tech_ssid
password: !secret tech_pw
fast_connect: true
manual_ip:
static_ip: 192.168.30.237
gateway: 192.168.30.1
subnet: 255.255.255.0
web_server:
light:
- platform: neopixelbus
type: GRB
internal: true
variant: WS2812
pin: $matrix_pin
num_leds: 256
color_correct: [30%, 30%, 30%]
gamma_correct: 2.0
restore_mode: ALWAYS_OFF
time:
- platform: homeassistant
display:
- platform: addressable_light
addressable_light_id: ehmtx_light
width: 32
height: 8
pixel_mapper: |-
if (x % 2 == 0) {
return (x * 8) + y;
return (x * 8) + (7 - y);
update_interval: 16ms
auto_clear_enabled: true
lambda: |-
// it.line(0, 0, 3, 0);
// it.line(8,0,11,0);
// it.line(16,0,19,0);
id(rgb8x32)->tick();
id(rgb8x32)->draw();
rotation: 180°
ehmtxv2:
icons2html: true
matrix_component: ehmtx_display
time_component: ehmtx_time
show_seconds: false
show_dow: false
show_date: false
rtl: true
clock_interval: 0
scroll_count: 1
scroll_interval: 80
default_font_id: default_font
default_font_yoffset: 8
special_font_id: special_font
special_font_yoffset: 6
allow_empty_screen: true
icons:
- id: error
lameid: 40530
- id: home_assistant
lameid: 47693
- id: temperature
lameid: 2056
- id: lightbulb
lameid: 1762
- id: music
lameid: 45625
- id: phone
lameid: 1232
- id: car
lameid: 2819
- id: sleep8x32
url: https://user-images.githubusercontent.com/16407309/224850723-634c9b2d-55d9-44f2-9f93-765c0485b090.gif
- id: tornado
lameid: 2153
- id: sleeping
lameid: 6232
- id: biking
lameid: 22841
- id: running
lameid: 32199
- id: obacht
lameid: 15303
- id: klo
lameid: 53659
- id: w_rain
lameid: 72
- id: w_sunny
lameid: 2282
- id: w_cloudy
lameid: 2283
- id: w_partly_cloudy
lameid: 2286
- id: w_clear_night
lameid: 13345
- id: sunset
lameid: 2859
- id: sunrise
lameid: 2860
on_next_screen:
- homeassistant.event:
event: esphome.new_screen
data_template:
iconname: !lambda "return icon.c_str();"
text: !lambda "return text.c_str();"
error:
INFO ESPHome 2024.12.2
INFO Reading configuration /config/esphome/display.yaml…
WARNING
WARNING This will only work with esphome >= 2023.7.0
WARNING Please check the documentation and wiki GitHub - lubeda/EspHoMaTriXv2: A simple DIY status display with a 8x32 RGB LED matrix, implemented with esphome.io and Home Assistant.
WARNING
ERROR Unable to load component ehmtxv2:
File “/esphome/esphome/loader.py”, line 177, in _lookup_module
module = importlib.import_module(f"esphome.components.{domain}")
File “/usr/lib/python3.11/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1206, in _gcd_import
File “”, line 1178, in _find_and_load
File “”, line 1149, in _find_and_load_unlocked
File “”, line 690, in _load_unlocked
File “”, line 940, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/data/external_components/e7db8eef/components/ehmtxv2/init.py”, line 247, in
CONFIG_SCHEMA = cv.All(font.validate_pillow_installed, EHMTX_SCHEMA)
AttributeError: module ‘esphome.components.font’ has no attribute ‘validate_pillow_installed’
Failed configehmtxv2: [source /config/esphome/display.yaml:206]
Component not found: ehmtxv2.
icons2html: True
show_seconds: False
show_dow: False
show_date: False
rtl: True
clock_interval: 0
scroll_count: 1
scroll_interval: 80
i have found some topics pointing in direction of wrong (old) python version, is this the right direction?
