Are you using the same login/pass info for the component as the app?
I can’t say I’ve rebooted often lately, but I haven’t run into any issues when I do. The app hasn’t been updated since august so I don’t believe there were any server side changes recently.
yeah - cant see a way to create another user (other than the partner account, which she is using) guess they werent planning on having 3 people in bed - how narrow minded lol
I use the same login for the app and HA and it generally works well. The odd time I restart HA it doesn’t load the component but it’s not that often. Maybe 1/10 times and usually it’s because I’ve lost connection at the hub
i have been also - i ended up disabling and as it happens there was a loose cable in the mattress cover - not sure if its related as i was able to hit the client ‘API’.
400 error is for a bad request. I’ve noticed in my log the api has been more in and out in recent weeks. Sometimes you just need to wait a bit and try again.
OK, I found the issue. I was using special character in my password. Removing the special character from my account pass solved the issue. Hmmm, no special characters in pass in 2018… LOL
Glad you got it figured out. Yeah that’s odd it doesn’t like special characters. Mine is just numbers and letters so that does make sense that was the issue.
I also don’t use special characters in my Eight password so it’s not something I would have caught in testing. Have you tried supplying the password with and without quotes in the config? The passing of the password to the api is a simple string substitution, nothing something that should have a problem with special characters.
so just had the eight_sleep mattress cover replaced (previous frayed wire).
just set up the new one and got the same error.
I’ve tried signing out of the app on my phone incase there is an issue like ring or arlo (using the same creds)
I DID have a special character in my password but removed that a while back troubleshooting.
