Can I use a Shelly Plus 1 switch to control a bluetooth enabled roller blind. Spacifically “Tuiss SmartView Blinds - Bluetooth” ? or if there are any "in pricipal " insights out there.
All thoughts much appreciated,
Mark
Re-opening this, as I’m also looking for a way to control blinds.
Are/were you trying to control Blinds2go Tuiss/Smartvire blinds?
Did you find a solution?
I see that there’s an integration, but it doesn’t seem to be current.
Yes I did have it working with the integration using bluetooth, but moved to a bigger house and have hard wired a shelly device in to an OEM had control. Not quite in the spirit of home assistant OS but better suited to my skill set
