I have a domestic hot water heat pump Stiebel Warmwasser-Wärmepumpe WWK 300 and a PV system.
Using evcc, I have integrated a Shelly 1 which switches on the heat pump when there is a PV surplus. This also works without any problems.
I have plugged a Plug S in front of the heat pump so that I can measure my electricity consumption.
Unfortunately, I can now only see how much electricity I consume, but not what comes from the PV system and what comes from the “socket”.
Is there a way to count the power consumption when the Shelly 1 is switched on (i.e. PV surplus). I could then calculate total consumption - PV surplus and thus have consumption from the “socket”.
Hello Miwyf
Thank you for your reply.
What kind of electricity meter do I still need?
I have the “electricity meter” from Solaredge, which counts what comes from PV and what comes from the grid.
However, I have the Plug S, which also indicates how much electricity I have consumed. Now I thought it might be possible to create an “automation” that starts a second count when the Shelly1 is switched on by evcc.
Unfortunately, I am not familiar enough with yaml programming to be able to do this on my own.
Maybe someone has already “tinkered” something like this for their whale box, because I would also like to implement this, but I thought I would start with the smaller Shelly first.
Then the go-E charger Gen3 wallbox would be next.
Thanks for your help.
Unfortunately, everything is full of snow at the moment, so I’m not even getting 1 watt from the PV system.
Hello an a happy new year.
Sorry that i anwere just now, but Christmas and so on. you know.
Oh man i got crazy with this automation.
I just wanted Homeassistant to count the power consumption of the Shelly plug-s when the Shelly 1 has the status “on”, but somehow I can’t get it to work.
Maybe someone can help me, I have tried the following.
alias: Stromzähler Warmwasser bei PV überschuss
