I reversed the uart communication protocol of my Electrolux Centurio IQ 2.0 and want to share this work to community.
You can control your boiler without cloud via ESPHome. You just need to replace original dongle with custom one. I am not familiar with soldering so I bought ready-made fully open source uni-iot-dongle.
Full source code and quite easy installation can be found here:
Also I am happy to get feedback and help with future reversing to add more features.
Additionally it have a chance to work with Ballu and Zanussi water heaters
Hi all.
Thanks, dentra for your work and sharing.
During the compiling I have an error:
Compiling /data/water-heater/.pioenvs/water-heater/src/esphome/components/ewh/ewh_utils.cpp.o
In file included from src/esphome/components/ewh/climate/ewh_climate.h:10,
from src/esphome/components/ewh/climate/ewh_climate.cpp:3:
src/esphome/components/ewh/climate/../ewh_component.h:5:10: fatal error: esphome/components/text_sensor/text_sensor.h: No such file or directory
5 | #include "esphome/components/text_sensor/text_sensor.h"
compilation terminated.
*** [/data/water-heater/.pioenvs/water-heater/src/esphome/components/ewh/climate/ewh_climate.cpp.o] Error 1
In file included from src/esphome/components/ewh/ewh_component.cpp:4:
src/esphome/components/ewh/ewh_component.h:5:10: fatal error: esphome/components/text_sensor/text_sensor.h: No such file or directory
*** [/data/water-heater/.pioenvs/water-heater/src/esphome/components/ewh/ewh_component.cpp.o] Error 1
The fix is very simple, just add the string text_sensor: after the substitutions section
Всем привет. Спасибо за проделанную работу. iot-uni-dongle не доступен для покупки и я нашел замену. Купил Модуль CH340G USB/TTL драйвер преобразователя, CH340, ESP8266, ESP-07 и залил в него ESPHome прошивку. esphome run .\ewh.yaml использовал board: “esp07” в конфигурации. На модуле есть переключатель для режима программирования, но в режиме UART он не заработал. Не смог работать с Electrolux, если быть точнее.
Может кому то будет полезна эта информация. Обнаружил проблему с подключением к Wi-Fi, если сеть скрыта. можно использовать только открытые сети. Пока не смог победить подключение к облаку. При включении Water Heater Cloud устройство уходит в перезагрузку. Пишет Connection estabilished и перезагружается. Может кому то удалось настроить эту функцию?
Добрый день! Я новичок в этом деле, это мой первый опыт использования ESPhome. Стараюсь все делать по инструкции, но пока не получается. Можно по подробнее узнать в какой конфиг нужно добавить эти строки? Если честно пока не совсем понимаю порядок действий. Мой порядок такой:
захожу в HA в FailEditor, создаю в папке ESPHome файл допустим “Water-Heater.yaml” в него копирую ваш код с Гитхаба, который EWH.
Захожу в HA в ESPBuilder вижу добавленную карточку, нажимаю EDIT, открывается файл с кодом.
нажимаю INSTALL в правом верхнем углу, выбираю ручную установку, после этого появляется окно с установкой.
после установки предлагается выбрать версию, выбираю MODERN, сохраняется файл в формате .bin
вставляю Lilygу в компьютер зажав на нем кнопку. 2 захожу Web ESPhome, коннекчусь с ним выбирая COM порт.
На вкладке ESPDevice выбираю INSTALL, далее выбираю тот файл который был ранее скачан в формате .bin жму INSTALL идет загрузка, все успешно, файл загружен.
Непонятны дальнейшие действия, если я вставляю контроллер в водогрейку, ничего не происходит, на вкладке ESP пишет OFFLINE, подскажите куда смотреть или нужен иной порядок действий? заранее спасибо! Я как обычный пользователь только начинаю вникать в эту тему. Очень благодарен таким людям как вы, которые разбираются в прошивках и делают их общедоступными для таких пользователей как я))
