Elevated Sensors Bed sensor first impressions & teardown
So, I wanna share my first impressions about the ESPHome based bed sensor from Elevated Sensors.
I’m not getting any incentive from the sensor provider. I’ve acquired the sensors with my own resources and want to share here my honest feedback.
I will update this post as I discover more.
Buying
Their website is quite easy to navigate and I haven’t had any issue buying the sensors.
Shipping
After submitting my order, I got a tracking number, however, after a few weeks, I got a message from the carrier saying it was retained at customs for tax collection, but this was with a different tracking number.
After paying the taxes, I got the package in a couple of days.
The package came from China and a paper bag. Well sealed, but not the best protection for the sensor’s boxes. Looks cheap packaging.
The two sensors boxes looks ok. Not the most fancy boxes, but it did the job and protected the sensors and accessories very well.
In the box
The card in the box have a QR code pointing to their docs website where you will find comprehensive installation instructions.
Apart of the card, you will find in the box:
  1. The device itself
  2. Two sensor strips, with an embedded 3M tape for mounting
  3. Two pairs of “extensions”, which are the same jumper cables you might have already at home
  4. A small piece of dual face tape (looks cheap)
  5. A screw for fixing the device to your bed
The device
It’s basically the PCB covered by a plastic cover (looks like 3D printed in draft mode).
It’s powered by a USB-C port.
Teardown
Removing the 4 screws gives you easy access to the board, where you can see an ESP32-C3-WROM and a “boot” button. I couldn’t find the pins for flashing in case you cannot do OTA, but USB should work just fine.
On-boarding
When powering the sensor, a new AP named bed-presence-xxxxxx appeared, open, so it was pretty easy to connect to.
Unfortunately the captive_portal haven’t redirected automatically, so I had to manually open my browser and go to http://192.168.4.1/ in order to setup the Wi-Fi.
Once connected to my Wi-Fi, the device was easily found by Home Assistant and ESPHome Dashboard.
In overall, the process wasn’t hard, but I believe they could have added esp32_improv to make this process much easier. There are enough memory for this.
I will explore it more and share new findings here.
So I’m guessing it hasn’t got the chips onboard to allow flashing via the USB port?
USB works fine:
I’ve updated my text above.
@EdwardTFN Thanks for your purchase and for such a thorough review. I appreciate the feedback!
Shipping
In an effort to keep international shipping costs to a minimum for you, we’re using a shipping provider that uses USPS in the United States to get the package to a global distribution center. From there, it is sent internationally using the carrier that makes the most sense for that given country. The shipping number that starts with “AHOY” provides end-to-end tracking, but the number provided by your local carrier will be different. The tracking page will include an “Original” and “Delivery” tracking number.
We’ve also recently added faster international shipping options.
Can you help me understand what you mean by “package came from China”? All units are packaged and shipped from the USA.
As you noted, the boxes themselves are designed to protect the sensors, the padded mailer is just used to group the boxes together for shipments of more than one unit (and it’s recyclable just like a box!).
In the box
I’m always a fan of when a product includes 3M VHB, since I’ve found it to be a high quality tape. Are there alternative tapes people prefer?
The device
My 3D printer is offended (it’s actually printed in 0.2mm Standard mode). But, point taken. The general quality of the case could be better.
Teardown
As noted later on, the device can be flashed directly via the USB port.
On-boarding
The device is part of the Made for ESPHome program and includes esp32_improv to meet the requirements.
The factory config that it ships with includes esp32_improv, managed ota updates, and a couple other provisioning items that shouldn’t be necessary if you choose to import it into your ESPHome dashboard. If you import it into your dashboard, this config is written which is stripped back a bit since it shouldn’t have to be provisioned.
Did Bluetooth provisioning not work, or had you already manually flashed the device?
Let me know if you have any other questions I might be able to help with!
- Stephen @ Elevated Sensors
Just got mine as well and really am loving how simple & ‘out-of-the-box’ it is. I do wish that the options on the store page were based on bed occupants instead of (just) bed size, since I ordered only one sensor for a full -size bed when in actuality still need two sensors for the two occupants :sweat_smile:
What is the chip to the right of the ESPRESSIF chip labeled? I can’t quite see in the picture.
It’s a TLC556C (dual CMOS-based 555 timer). The circuit will be using the FSRs to control the frequency of free-running oscillators on the 556 and then measuring pulse frequencies on the ESP32. That’s a sensible bit of design because it removes the need to mess around with resistors to scale the output of a potential divider to get good sensitivity from an ADC pin as on other designs seen on this forum.
I dunno, man. It’s under a bed where no one will see it. Seems fine to me.
Tough crowd in here. :smile:
I was just thinking the exact same thing. Like, who cares about the 3D print job. No one sees it. As long as the thing is sturdy enough to live under a mattress, I’m good :wink:
I’m NOT happy here. I bought it, waited weeks for it to arrive, then went to the install instructions and found out I needed an “install kit” that isn’t included. It costs $10 more and is out of stock. I will NEVER buy from this perrson again. If your not going to include it, at least tell me its needed. No instructions are given for installing it without it.
You mean like they did right on the page where you ordered the sensor?
Or the FAQ section?
Or the many times this question was asked in the announcement thread?
Sorry mate, this one’s on you.
Unfortunately the ability to read (and understand what is written) is diminishing at a fast pace since quite a while already in a world where all is expected to be instant.
Hey sorry you had that experience. For context we started selling sensor kits designed for beds with slats only. The instructions for installing your kit on a bed with slats can be found at https://docs.elevatedsensors.com/bed-presence-mk1/getting-started/#slat-install. If you have slats, then you’re all set.
Lots of people were interested in using that kit on box springs, upholstered bases, flat boards, etc. We recently introduced the universal mounting kit as an add-on for those bed types. It isn’t needed for every install, so it’s not included with every order. We do our best to communicate all of this on the website, and try to keep the mounting kits as affordable as possible.
Installed with a latex mattress which is heavy. The unit is easy to adjust and works great! Been looking for something like this which you can adjust. Great work guys!
I’ve had these for awhile now on two beds. Can’t say I’m super happy with them. I have memory foam mattresses which may be the issue. I’m going to have to spend some time and make another attempt to get them working reliably.
Does anyone have any experience with hybrid mattress? So foam and springs?
Also I have a king size, with slats. Im seeing " King Mounting Kit InstallPermalink"
Is this a seperate kit or?
Feel free to reach out if you need assistance getting it to work reliably. We can help look at graphs and tune the Trigger Threshold.
My mattress is a Casper Hybrid. The separate mounting kit is not necessary for beds with slats, just if you’re installing on a box spring, upholstered base, solid platform, or foundation.
Finally had the time to install the sensor - first impressions are simply WOW! Had to extend thw wiring with a piece of dupont cable, but otherwise it was a smooth experience. Now it’s time to create automations based on bed presence :slight_smile: Thanks Stephen and keep up with the good work!
Hi, I’m interested in the device but I wanted to understand how to manage the lights and with which device, especially in the case of two people. When the sensor detects the first person in bed and turns off the light, how do I turn it back on when the second person enters the room? I’m currently using a millimeter sensor with ESP32, but it’s no longer detecting people, and I don’t know how to fix it. Do you have any products, sensors, or models you can recommend? Thanks.
