hi,
is elevation always in meters, or does it respect unit_system? the tutorial say it’s in meters but since unit_system in the tutorial is metric i wanted to be sure.
thanks!
hi,
thanks!
It will be unless you use this unit_system: imperial
I looked through the source code and I’m not 100% sure but everything I saw says elevation
is in meters no matter what unit_system
is set to.
Also, I noticed if you don’t put elevation
it will try to figure it out based other information. There is a CSV string of City data called _LOCATION_INFO
in astral.py
