ELK M1 Arming Problems
I have my ELK M1 Gold set up with HA and most things seem to work as expected - I can see the state of alarm sensors and they update in realtime. I’ve been able to build automations based on the state changes of sensors with no problems.
However one problem I’ve not been able to solve is that when I try to arm my system in any of the available modes, it just shows the flashing “Arming” state forever and never actually goes into the “Armed” state. The alarm system, however, does actually arm after the delay time. This is true whether I try to arm it via the Lovelace UI in HA, or by physical keypad.
One clue is that I do see it briefly blip into the “armed” state before it goes into the “arming” state. The log shows this as well. I’ve waited a couple minutes to see if the state eventually changes to “armed” but it never happens.
I have my M1G, M1XEP and keypad all running the latest firmware, and as far as I can tell I have all of the global settings in the RP software correct for working with HA.
Any ideas for what I can explore to further debug or fix this?
thanks,
Steve
Followup. I waited ever longer than I had before, and it does appear to eventually show the armed state in HA after 4+ minutes. Is this delay intentional, an integration bug, or something wrong with my setup?
Answering my own question, hopefully it will help someone else in the future. In the ELK RP Area Configuration, the “Exit 2” delay controls how long it takes for HA to show the armed state after arming.
It was set to 240 seconds previously, which explains the 4+ minute delay to show armed state.
