ELTAKO joins Works with Home Assistant
We’re delighted to welcome ELTAKO to the Works with Home Assistant program! ELTAKO’s robust relay switches have formed the blueprint for smart building and smart home control across Europe for decades – and happen to be the first Matter relays to join the program.
You may never have seen one of ELTAKO’s little blue devices before, and that’s the point. They usually sit quietly behind walls, furniture and in distribution boards, doing their jobs without interfering with interiors. Now, thanks to their joining the Works with Home Assistant program, you can bring these professional-level installations to your own smart set-up.
Out of the blue and into the open home
ELTAKO has been a well-known name in the German building trade and throughout Europe for more than 75 years. In fact, the name itself derives from ‘ELektrischer TAst-KOntakt’ (electrical push-button contact) in a nod to ELTAKO’s first impulse switch innovation that started it all back in 1949.
For those of us who haven’t been around quite that long, an impulse switch (also known as a latching or step relay) toggles a circuit on or off each time it receives an electrical pulse. Instead of requiring constant power, it ‘remembers’ its state until the next signal. As well as using less energy, this means it’s possible to control a single light or system from multiple switches without complex wiring – with obvious advantages for the smart home. So synonymous is the brand with this type of device that impulse switches are still referred to as ‘ELTAKOS’ by the professional electricians and engineers who use them.
Because of this innovative spirit, it’s perhaps no surprise that over the years ELTAKO has broadened its range to a full ecosystem of sensors, dimmers, and energy meters – all based on wired or wireless technologies, such as RS485, EnOcean, Modbus or DALI, which are built for longevity and local control, rather than cloud dependency.
True to that philosophy, ELTAKO has embraced open standards such as Matter, ensuring its products speak the same languages that support our mission to keep homes open, private, and locally controlled.
"As a manufacturer that has relied on open standards like Matter and EnOcean from the very beginning, joining the Works with Home Assistant program is a natural step for us. This allows us to make our products accessible to an even larger community and enables our customers to integrate them seamlessly into diverse smart home environments. We are convinced that the future lies in openness and interoperability – which is why we deliberately embrace partnerships that offer users long-term investment security and maximum flexibility."
- Kai Sepp, Sales Director North & West Europe at ELTAKO
Devices
ELTAKO’s integration with Home Assistant starts with items from the 64 series, which was awarded the SmartHome Germany Award this year. This is the brand’s line that uses Matter over Wi-Fi, showing just how serious they are about interoperability moving forward.
We were also lucky enough to see the ELTAKO team at ISE Barcelona this year, and we’ll be catching up with them again at the Connectivity Standards Alliance (CSA) meeting in November, also in Barca. Since CSA certification is a must for brands joining the program, it’s great to see ELTAKO so engaged.
As always, all the devices below have gone through our rigorous certification process to ensure they meet our standards for performance, reliability and open-home compatibility.
What devices have been certified?
These Matter devices that work over Wi-Fi are all about giving you freedom to control your current hardware – switch lights on and off and dim them automatically – without replacing it all. The shading actuator is particularly useful in continental Europe, where shutters are more common. It has a good energy-saving use case to reduce the need for air conditioning, since automatic shutters help keep your home cool in summer and warm in winter, potentially reducing utility bills. This also reflects ELTAKO’s wider focus on sustainability – from low-power devices to recyclable packaging and shipping materials.
In case you didn’t know, when using Matter devices with Home Assistant you have local control with no need for external internet for day-to-day operation. If you do want to access your dashboard while you’re away from home, using Home Assistant Cloud is a simple, secure, way to do this (and help fund Home Assistant’s development in the process!).
Professional quality, support for all
Like all brands within the Works with Home Assistant program, ELTAKO isn’t just adding our little blue logo to their little blue products – they’re joining our community. That means active engagement and shared expertise to help everyone get the best from their devices. Because ELTAKO’s products are built to professional standards, installation can sometimes require a qualified electrician – especially for wired set-ups. That’s where ELTAKO’s directory of system partners and specialists in many regions, as well as a tech support hotline, can help you find the installation advice you need, whether you’re a complete novice or electrical enthusiast.
With ELTAKO on board, we hope Home Assistant users will have further flexibility to explore new devices and experiment with different set-ups, as well as open up more ways to mix and match products to build a professional-standard smart home.
FAQs
Q: If I have a device that is not listed under ‘Works with Home Assistant’ does this mean it’s not supported?
A: No! It just means that it hasn’t gone through a testing schedule with our team or doesn’t fit the requirements of the program. It might function perfectly well but be added to the testing schedule later down the road, or it might work under a different connectivity type that we don’t currently test under the program.
Q: OK, so what’s the point of the Works with program?
A: It highlights the devices we know work well with Home Assistant and the brands that make a long-term commitment to keeping support for these devices going. The certification agreement specifies that the devices must have key functionality within Home Assistant, operate locally without the need for cloud, and will continue to do so long-term.
Q: How were these devices tested?
A: All devices in this list were tested using a standard HA Green Hub and with our certified Matter Integration. If you have another set-up that’s not a problem, but we test against these as they are the most effective way for our team to certify within our ecosystem.
Q: Will you be adding more ELTAKO devices to the program?
A: Why not! We’re thrilled to foster a close relationship with the team at ELTAKO to work together on any upcoming releases, or add in further products that are not yet listed here. We’re really excited about what ELTAKO are doing with EnOcean and green power generally, but we haven’t tested or certified any of these products yet. We don’t have this protocol as part of the Works with Home Assistant certification (even if people are already using EnOcean in Home Assistant), and could explore how we certify these kinds of products.
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2025/10/29/eltako-joins-wwha
Wondering if there will ever be any EnOcean products certified for the WWHA program?
Eltako is one of the few EnOcean products confirmed to be working out-of-the-box with HA:
Eltako could perhaps also make some Zigbee Green Power (ZGP) devices too as as that uses EnOcean technology for energy harvesting in batteryless devices (such as wireless remotes) :wink:
EnOcean Alliance looks to be alive and kicking but the standard seems to more or less only installed in commercial installations by professional installers and probably very seldom bought by DIY home users for private residential homes.
Competition is good so we could always hope they too will begin to target the DIY market :sunglasses:
I also hope, but for that I guess that the EnOcean integration must greatly evolve. This integration is stuck since years and needs to be rewritten. This integration doesn’t even include the pairing process and must be configured via yaml!
If someone from EnOcean alliance is reading this message, please invest a few time in Home Assistant integration, DIY users will thank you and will be more interested in your products.
If the Open Home Foundation have someone speaking Japanese then they could send someone to the EnOcean Alliance Japan Open Forum conference that is on the 28th of November 2025 :stuck_out_tongue_winking_eye:
As Sustainability is one of our key pillars we’d love to be able to certify EnOcean devices in the future but the comments above are correct, the integration needs to be further along and maintained regularly to be certifiable. Green power is on our radar for future planning though for sure.
Hear, hear.
I’m using quite a lot of Eltako EnOcean devices, but they’re currently added to Home Assistant via MQTT. In IP Symcon, I have to set them up twice, once as EnOcean device and once as MQTT device, essentially creating an MQTT bridge between IP Symcon and Home Assistant. There really should be a straightforward, configurable integration in Home Assistant that directly supports EnOcean/LAN gateways.
In case you didn’t know: GitHub - grimmpp/home-assistant-eltako: Integration for Eltako 14 series in Home Assistant
I have this up running quite stable. It was a hassle to set up with the addresses and such, but it works reliable enough.
