I’d like to be able to email to myself the state of my HA components (preferably including some history). The purpose is because my HA system is only local and I only interact with it via email when not on the network.
One approach I was considering is to extract information from the Logbook entries that I understand are stored in home-assistant_v2.db. However, this file is too big to email.
Is there a way to extract just the current day’s entries from home-assistant_v2.db
Alternately, is there a different way to easily obtain the state of all components?
Thanks!
Would working on an exception principle work? Then you can review overall changes when back on your network? Send a notification if something goes offline, a door opens, a temp threshold is met? This is very easy to implement with a few automatons.
Essentially, I’d like to either: 1) email out the state of my system (e.g. info available on front end, or state of all sensors) - my system right now is only available on my home network; and optionally 2) also include in that the ‘history’, so that I can see what is going on when I’m not home.
