Email Notifications
I created an automation to send me an email when water is detected in a bathroom. I received the email. Is it possible to send email when the opposite is true, such as dry? Within the same automation?
Below is what i created using UI.
alias: Leak Detected
description: ""
triggers:
  - type: moist
    device_id: 83ea2ce28774b28da892d6ba6db168f8
    entity_id: 80de19b099e6dc7ca4b64f332050672e
    domain: binary_sensor
    metadata:
      secondary: false
    trigger: device
conditions: []
actions:
  - action: notify.mobile_app_bob_s_phone
    metadata: {}
      message: Leak detected in upstairs bathroom
      title: Water Leak
  - action: email_notifier.send
      account: notify.email_notification_sender_1
      recipients: email address
      title: Leak Deteced
      message: Leak detected in upstairs bathroom!
mode: single
Yes, there are several ways.
One basic option is to just add the “not_moist” version of your current trigger and to use trigger IDs to conditionally branch actions in an If/Then or Choose action.
Example Automation Configuration
description: ""
triggers:
  - id: moist
    type: moist
    metadata:
      secondary: false
    trigger: device
  - id: dry
    type: not_moist
    metadata:
      secondary: false
    trigger: device
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
        sequence:
            metadata: {}
              title: Water Leak
              title: Leak Detected
      - conditions:
        sequence:
            metadata: {}
              message: Dryness detected in upstairs bathroom
              title: Leak Sensor Dried Out
              message: Dryness detected in upstairs bathroom!
mode: single
But, there are many other ways to do the same thing using other types of triggers and templating to make a more concise automation.
Great, thank you so much. I will try and understand the logic and use it for future automation.
