I have Home- assistant core and grafana as two seperate containers in docker.
Both are accessible with two ssl addresses (Let’s encrypt certificate)
Because both containers have the same local ip-adress I wonder if it should be possible to have an I-frame or panel with an url like https://xxxx.duckdns.org:1234, while home assistant has an url like https://aaa.duckdns.org:5678 ?
The I-frame now shows an error saying https://aaa.duckdns.org refuses to connect. At some point I can understand this because it is something like a circular “thing”. But I hope someone succeeded in embedding a grafana panel while using a secure url.
