Embedded MQTT Broker - No Authentication
Good day all.
Would just like to find out if there is a way to use the Embedded MQTT broker without authentication?
It seems it forced the homeassistant username at all times and if you don’t specify a password it just doesn’t start up.
I know the obvious answer would be to run a separate instance of MQTT, but I’ve been happily using the Embedded broker for months without issue but need to test something that doesn’t support MQTT authentication and seems there is no simple way to get that done.
Hoping I’m missing something easy and simple.
