Hi, i want to use the embedded mqtt, but the 8080 is already in use, so i tried changing it
mqtt:
embedded:
listeners:
default:
max-connections: 5000
bind: 192.168.0.17:1883
type: tcp
ws-1:
bind: 192.168.0.17:8888
type: ws
auth:
plugins: ['auth.anonymous']
allow-anonymous: true
but i receive the error below
2019-01-10 20:53:24 WARNING (MainThread) [hbmqtt.broker.plugins.topic_taboo] ‘topic-check’ section not found in context configuration
2019-01-10 20:53:24 ERROR (MainThread) [homeassistant.components.mqtt] Unable to start embedded MQTT broker
2019-01-10 20:53:25 ERROR (MainThread) [homeassistant.setup] Setup failed for mqtt: Component failed to initialize.
