Hi Guys,
I am facing a very annoying issue.
My current status:
My HA is working quite well, despite some small errors, I will worry about, as soon the most annoying issue is solved.
So… my HA is working well on Rapsi4.
Check Configuration shows à Configutation valid! (green)
My devices also show history when I look at it. Some week ago I had the topic, that it was not possible, I think because it started a corrupt home-assistant_v2.db.corrupt.yaml, I just deleted it, but it still exists.
When I am starting my HA through Sever Controls, everything is fine.
The problem begins, when I have to hard reset (pull plug) my raspi4.
Why am I hard reseting?
Sometimes, I would estimate once per week, my HA stops working.
When I want to restart server from HA frontend I get the information: “failed to call service homeassistant restart… → Reason utf-8 entry in configuration.yaml”
I didnt change anything in the yaml.
Now begins the problem:
My Raspi4 is booting in emergency mode. (see picture1)
When I type in dmesg I get following information (see picture 2)
Finally I continue by pressing Control-D.
HA starts normally and it works.
The problem is, that all entities I added since my last restart are not shown in HA anymore.
From those who are still existing in HA, some of them are not available anymore and I have to connect them again.
Also my created automations and dashboards I created since last restart don’t exist anymore.
I assume, that it has something to do with the emergency mode.
I hope I have not shared any confidential information from my system
I also hope that you see a way how to setup my Rapsi/HA, so that I can go on configurating my HA.
Kind Regards
AK
