EMHASS: An Energy Management for Home Assistant
Thanks a lot for your help, I thought that no data is being fed, so I just checked the deferrable load entity from time to time if they got changed or not. I also changed some details in the configuration and later discovered that the UI got updated with all the data. The P_deferrable in UI is spot on, but I struggle to get it into HA. The reason why I said that no data is being fed is because of the log:
[2022-09-04 20:25:00,808] INFO in web_server:  >> Publishing data...
[2022-09-04 20:25:00,809] INFO in command_line: Publishing data to HASS instance
[2022-09-04 20:25:00,904] INFO in retrieve_hass: Successfully posted to sensor.p_pv_forecast = 1391.13
[2022-09-04 20:25:00,946] INFO in retrieve_hass: Successfully posted to sensor.p_load_forecast = 169.94
[2022-09-04 20:25:00,989] INFO in retrieve_hass: Successfully posted to sensor.p_deferrable0 = 0.0
[2022-09-04 20:25:01,033] INFO in retrieve_hass: Successfully posted to sensor.p_deferrable1 = 0.0
[2022-09-04 20:25:01,077] INFO in retrieve_hass: Successfully posted to sensor.p_grid_forecast = -1221.19
[2022-09-04 20:25:01,118] INFO in retrieve_hass: Successfully posted to sensor.total_cost_fun_value = -0.61
It just keeps publishing the “default” values, instead of the ones I am seeing in UI.
I might be missing something totally obvious for you, but my lack of experience and language skills makes it quite challenging for me. Thanks for any suggestions.
Little edit:
Just noticed that the result table does not contain data unless I manually press the Perfect Optimization. I do have these lines in /config/configuration.yaml
And these lines in /config/automations.yaml
Are those the automatization you were talking about? I hope I did not miss any.
Hello all,
Seems to me I have issues with module and inverter name. If I understood well the documentation (chapter Configuration File) I need to find as close model as possible in SAM/deploy/libraries at develop · NREL/SAM · GitHub and to replace the special chars by underscore.
If I use the model used in the example (‘CSUN_Eurasia_Energy_Systems_Industry_and_Trade_CSUN295_60M’ and ‘Fronius_International_GmbH__Fronius_Primo_5_0_1_208_240__240V_’) everything works.
However if I try to insert ‘GoodWe_Technologies_Co___Ltd___GW9600A_ES__240V_’ or module ‘LONGi_Green_Energy_Technology_Co__Ltd__LR5_66HBD_490M’) I get following error message in log after clicking on Day-Ahead Optimization. See at the end of my post.
Am I missing anything? Or I need to pass somehow the information about used module/invertor?
Thank you
[2022-09-08 22:02:24,044] ERROR in app: Exception on /action/dayahead-optim [POST]
File “/usr/local/lib/python3.9/dist-packages/pandas/core/indexes/base.py”, line 3621, in get_loc
return self._engine.get_loc(casted_key)
File “pandas/_libs/index.pyx”, line 136, in pandas._libs.index.IndexEngine.get_loc
File “pandas/_libs/index.pyx”, line 163, in pandas._libs.index.IndexEngine.get_loc
File “pandas/_libs/hashtable_class_helper.pxi”, line 5198, in pandas._libs.hashtable.PyObjectHashTable.get_item
File "pandas/libs/hashtable_class_helper.pxi", line 5206, in pandas.libs.hashtable.PyObjectHashTable.get_item
KeyError: 'GoodWe_Technologies_Co___Ltd___GW9600A_ES__240V
File “/usr/local/lib/python3.9/dist-packages/flask/app.py”, line 2525, in wsgi_app
response = self.full_dispatch_request()
File “/usr/local/lib/python3.9/dist-packages/flask/app.py”, line 1822, in full_dispatch_request
rv = self.handle_user_exception(e)
File “/usr/local/lib/python3.9/dist-packages/flask/app.py”, line 1820, in full_dispatch_request
rv = self.dispatch_request()
File “/usr/local/lib/python3.9/dist-packages/flask/app.py”, line 1796, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File “/usr/local/lib/python3.9/dist-packages/emhass/web_server.py”, line 134, in action_call
input_data_dict = set_input_data_dict(config_path, str(config_path.parent), costfun,
File “/usr/local/lib/python3.9/dist-packages/emhass/command_line.py”, line 76, in set_input_data_dict
P_PV_forecast = fcst.get_power_from_weather(df_weather)
File “/usr/local/lib/python3.9/dist-packages/emhass/forecast.py”, line 337, in get_power_from_weather
inverter = cec_inverters[self.plant_conf[‘inverter_model’][i]]
File “/usr/local/lib/python3.9/dist-packages/pandas/core/frame.py”, line 3505, in getitem
indexer = self.columns.get_loc(key)
File “/usr/local/lib/python3.9/dist-packages/pandas/core/indexes/base.py”, line 3623, in get_loc
raise KeyError(key) from err
The problem is that your module and inverter models are not found in the database. This is a recurrent problem.
You should look if your models are available. If they are not avalable, solution (1) is to pick another model as close as possible as yours in terms of the nominal power.
The available module models are listed here: https://github.com/davidusb-geek/emhass-add-on/files/9234460/sam-library-cec-modules-2019-03-05.csv
And the available inverter models are listed here: https://github.com/davidusb-geek/emhass-add-on/files/9532724/sam-library-cec-inverters-2019-03-05.csv
Solution (2) would be to use SolCast and pass that data directly to emhass as a list of values from a template. Take a look at this example here: The forecast module — emhass 0.3.18 documentation
I checked your module model and there are no 490W models or even 500W models on the database, so you are better off going with solution (2)
Oh, now I can see the problem I am facing, the SAM library included in the EMHASS is not up to date, judging by the date in the file name " 2019-03-05" I checked the file and did not find the module and inverter models, that I can see in the link documentation refers to:
The complete list of supported modules and inverter models can be found here: pvlib.pvsystem.retrieve_sam — pvlib python 0.10.3 documentation
This link then refers to :
Files available at
These files are not the same. The inverter Daman is talking about is listed in the original SAM libraries, but not in the EMHASS one. So I just wanted to point out to others, who did use the link from documentation, that it may contain the models you are looking for, but may not work.
Hi, I’ve just updated this in the documentation.
Hi David,
Thank you for a very cool project!
I’ve followed the example from haraldov to get a list from Nordpool as well as the example in The forecast module — emhass 0.3.18 documentation to get SolCast forecast data.
I’ve defined these shell_commands:
post_nordpool_forecast:
‘curl -i -H ‘‘Content-Type: application/json’’ -X POST -d ‘’{“load_cost_forecast”:{{(
(state_attr(’‘sensor.nordpool’’, ‘‘raw_tomorrow’’)|map(attribute=’‘value’’)|list)[:24])
}},“prod_price_forecast”:{{(
(state_attr(’‘sensor.nordpool’’, ‘‘raw_tomorrow’’)|map(attribute=’‘value’’)|list)[:24])}}}’’ http://localhost:5000/action/dayahead-optim
post_mpc_optim_solcast:
}}, “pv_power_forecast”:{{states(’‘sensor.solcast_24hrs_forecast’’)
}}}’’ http://localhost:5000/action/naive-mpc-optim
When I use the shell_command post_nordpool_forecast it seems to work and I get a list for the entire , but when I use post_mpc_optim_solcast the list stops at 10 am. I have a feeling it has to do with the fact that solcast sends 48 values, but Nordpool only sends 24 values, but I’m not sure.
Is there a way to combine Nordpool data with solcast forecast data?
Warmly, Per Takman
Hi, what do you mean by combine? Nordpool is giving you load cost and production prices forecasts in currency units while Solcast is giving you PV power forecast in Watts. How to combine different quantities? Or I don’t understand your problem with that.
The data is being truncated when using MPC because of the working principle of that algorithm and the prediction horizon parameter.
To control that you need to define additional parameters when using MPC, for example :
"prediction_horizon":10,soc_init":0.5,"soc_final":0.6,"def_total_hours":[1,3]
…if you have a battery and two deferrable loads.
Hi! I was not referring to combining price with watts. :slight_smile: I thought something was wrong becuase I did not see a result that covered the entire next day. My assumption was that 24 datapoints from Nordpool vs. 48 datapoints from solcast caused the problem.
From your answer I take it that MPC does not offer a prediction for the entire next day. Sounds like I need to study this in more detail.
@per.takman
Nordpool publish tomorrow power prices every day at 13:00. Sometimes the Nordpool plugin do not update the prices. I use a automation which trigger the shell command at 23:57 every day. I then get the prices from 00:00 the next day in emhass.
alias: EMHASS day-ahead optimization
description: ""
  - platform: time
    at: "23:57:00"
condition: []
  - service: shell_command.post_nordpool_forecast
    data: {}
You can see if the tomorrow price data is available with Developer Tools->State:
If you are sending emty raw_tomorrow list the column unit_load_cost and the cost_profit in the emhass webpage do not update. If it work check also the price data are in the correct time index.
The shell_command I use now is this one:
shell_command:
  publish_data: "curl -i -H 'Content-Type:application/json' -X POST -d '{}' http://localhost:5000/action/publish-data"
    'curl -i -H ''Content-Type: application/json'' -X POST -d ''{"load_cost_forecast":{{(
    (state_attr(''sensor.nordpool'', ''raw_tomorrow'')|map(attribute=''value'')|list)[:24])
    }},"prod_price_forecast":{{(
    (state_attr(''sensor.nordpool'', ''raw_tomorrow'')|map(attribute=''value'')|list)[:24])}}}'' http://localhost:5000/action/dayahead-optim'
Hi again,
Sorry about not being clear in my first post. I believe that I’ve followed the instruction now, but I still think that the fact that Nordpool publish 24 values and solcast publish 48 values cause a problem. Please bear with me.
After stumbling a bit on the syntax in Studio Code Server I now have the following shell commands:
dayahead_optim:
  (state_attr(''sensor.nordpool_kwh_se3_sek_3_10_025'', ''raw_tomorrow'')|map(attribute=''value'')|list)[:24])
  (state_attr(''sensor.nordpool_kwh_se3_sek_3_10_025'', ''raw_tomorrow'')|map(attribute=''value'')|list)[:24])}}}'' http://localhost:5000/action/dayahead-optim'
mpc_optim:
  'curl -i -H "Content-Type: application/json" -X POST -d ''{"load_cost_forecast":{{(
  }}, "prod_price_forecast":{{(
  }}, "pv_power_forecast":{{states(''sensor.solcast_24hrs_forecast'')
  }}, "prediction_horizon":48,"soc_init":{{(states(''sensor.r2_d2_battery_level'')|float(0))/100
  }},"soc_final":0.05,"def_total_hours":[2]}'' http://localhost:5000/action/naive-mpc-optim'
dayahead_optim and publish_data both execute sucessfully, but mpc_optim generate the following log trace in the EMHASS add-on:
[2022-09-12 22:57:35,264] INFO in command_line: Setting up needed data
[2022-09-12 22:57:35,272] INFO in retrieve_hass: Retrieve hass get data method initiated...
[2022-09-12 22:57:36,221] INFO in forecast: Retrieving weather forecast data using method = list
[2022-09-12 22:57:36,231] INFO in forecast: Retrieving data from hass for load forecast using method = naive
[2022-09-12 22:57:36,233] INFO in retrieve_hass: Retrieve hass get data method initiated...
[2022-09-12 22:57:39,148] ERROR in app: Exception on /action/naive-mpc-optim [POST]
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 2525, in wsgi_app
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1822, in full_dispatch_request
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1820, in full_dispatch_request
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1796, in dispatch_request
  File "/usr/local/lib/python3.9/dist-packages/emhass/web_server.py", line 134, in action_call
  File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 112, in set_input_data_dict
    df_input_data_dayahead = copy.deepcopy(df_input_data_dayahead)[df_input_data_dayahead.index[0]:df_input_data_dayahead.index[prediction_horizon-1]]
  File "/usr/local/lib/python3.9/dist-packages/pandas/core/indexes/base.py", line 5039, in __getitem__
    return getitem(key)
  File "/usr/local/lib/python3.9/dist-packages/pandas/core/arrays/datetimelike.py", line 341, in __getitem__
    "Union[DatetimeLikeArrayT, DTScalarOrNaT]", super().__getitem__(key)
  File "/usr/local/lib/python3.9/dist-packages/pandas/core/arrays/_mixins.py", line 272, in __getitem__
    result = self._ndarray[key]
IndexError: index 47 is out of bounds for axis 0 with size 24
  1. Is there a way to use MPC together with data from Nordpool? Should I be using a different service for pv_power_forecast with 60 minute intervals?
  2. Is it sufficient to only use dayahead_optim once a day and then publish every 5 minutes?
  3. Does anybody have good example how to control battery based on sensor.p_batt_forecast?
Cheers, Per Takman
You need to ensure that the data you pass have the same number of elements.
Either 24 x60 minute intervals or 48 x30 minute intervals you can’t mix 24 values for price and 48 values for production.
I would suggest you just focus on price only and use the internal pvlib solar forecast to start.
In your case you have 24 x60 price forecasts so you need to change your time interval to 60 minutes.
Using the internal pvlib solar forecast is reasonable, but don’t worry if you don’t have exact models to match.
Once you get EMHASS writing with price forecasts, then as a second stage you can look to integrate the external solar forecasts.
Hi Mark,
I’ve already set the optimization time step to 60 to make Nordpool with their 24 data points work.
Your suggestion to use the internal pvlib solar forecast sounds good. Can I do this by simply removing the line
in my shell command mpc_optim?
The new shell command would then be:
mpc_optim:
Thank you in advance!
/Perr
Yes that is looking simpler, which is easier to debug.
You should also change prediction_horizon from 48 to 24 to match the 24 elements you are passing.
It really depends on which battery you have and the controls available to you in Home Assistant.
I have a Tesla powerwall2 and use the Tesla Gateway custom integration.
One automation that sets backup_reserve_percent based off the EMHASS state of charge forecast:
alias: Battery SOC Forecast
description: ""
  - platform: state
    entity_id:
      - sensor.soc_batt_forecast
condition: []
  - service: tesla_gateway.set_reserve
      backup_reserve_percent: "{{states('sensor.soc_batt_forecast')|int(0)-5}}"
I also have an alternative method by changing the battery modes, which roughly does the right thing. This also has some alerts so I can monitor the mode changes.
alias: p_batt automation
description: ""
  - platform: numeric_state
    entity_id: sensor.p_batt_forecast
    below: "-1000"
    above: "-1000"
    below: "4900"
    above: "4900"
condition: []
  - choose:
      - conditions:
          - condition: numeric_state
            below: "-1000"
          - service: notify.mobile_app_pixel_6
              title: p_batt alert {{states('sensor.p_batt_forecast')}} - mode:backup
              message: price:{{states('sensor.amber_general_price')}} $/kWh
          - service: tesla_gateway.set_operation
              real_mode: backup
              backup_reserve_percent: 3
      - conditions:
            above: "4900"
            enabled: false
              real_mode: autonomous
              backup_reserve_percent: 1
            enabled: false
              title: >-
                p_batt alert {{states('sensor.p_batt_forecast')}} - consider
                mode:autonomous
              message: Price:{{states('sensor.amber_general_price')}} $/kWh
    default:
          real_mode: self_consumption
          backup_reserve_percent: 2
          title: >-
            mode:self_consumption
Thank you Mark!
I no longer get errors after reducing the prediction horizon to 24 instead of 48 regardless of whether I use mpc_optim or mpc_optim3 where I use solcast_24hrs_forecast. However, I get the impression that I either should not run it directly after a dayahead_optim or that something else is wrong.
mpc_optim:
  }}, "prediction_horizon":24,"soc_init":{{(states(''sensor.r2_d2_battery_level'')|float(0))/100
mpc_optim3:
The EMHASS log looks like below:
[2022-09-12 23:46:04,315] INFO in command_line: Setting up needed data
[2022-09-12 23:46:04,326] INFO in retrieve_hass: Retrieve hass get data method initiated...
[2022-09-12 23:46:05,427] INFO in forecast: Retrieving weather forecast data using method = list
[2022-09-12 23:46:05,436] INFO in forecast: Retrieving data from hass for load forecast using method = naive
[2022-09-12 23:46:05,438] INFO in retrieve_hass: Retrieve hass get data method initiated...
[2022-09-12 23:46:08,698] INFO in web_server:  >> Performing naive MPC optimization...
[2022-09-12 23:46:08,698] INFO in command_line: Performing naive MPC optimization
[2022-09-12 23:46:08,726] INFO in optimization: Perform an iteration of a naive MPC controller
[2022-09-12 23:46:08,896] INFO in optimization: Status: Infeasible
[2022-09-12 23:46:08,897] INFO in optimization: Total value of the Cost function = 0.0
What does Status: Infeasible mean? The total value of the cost function is zero.
My understanding is the nordpool pricing is only updated once a day. There are some considerations you need to take into effect.
You will get a reasonable optimisation from EMHASS if you only call the optimisation once a day as well. For debugging purposes you can call many times whilst trying to setup.
Can you drop your shell command into the developer template section so we can see the expansion of variables.
Whilst you are setting up, drop def_hours to 0 until you get the basic functionality working.
EMHASS expects the list of prices to be relative to the current time. Thus the first price in the list should correspond to the first timeslot (ie next 60 minutes), the second element in the list should correspond to the next timeslot and so on. So if you call the optimisation at 09:45, it is expecting to see the prices for 10:00, 11:00, and so on.
My understanding is the nordpool sensor is only updated every 24 hrs. I’m not sure what time reference they use, but for example if the nordpool data always starts at midnight, the first element in the list will always refer to 01:00, the second element 02:00 and so on. It is upto you to ensure the data fed to EMHASS referes to the correct time slot, alternatively you can call the optimisation once a day at the correct time.
Can you also share what you see at http://homeassistant.local:5000 which should show the results after an optimisation.
Nordpool offers todays prices starting from 00 to 01 and so on. In addition, they publish next day prices at 13 every day. This means that the first element in the list I’m sending is for 00 to 01.
To me it sounds like I should stick with the dayahead_optim and skip MPC for now.
That sounds sensible.
MPC only improves the optimisation when your variables are changing very quickly.
My energy provider updates and changes their prices every 5 minutes, based off the national energy market wholesale bidding prices so for me the added complexity of getting MPC functional had a lot of benefits.
I’m still in the plan and prepare phase for our solar panel and battery storage investment, which is why I’m playing around with this add-on.
One thing I’ve been wondering is how people with battery storage solutions factor in the cost of using the battery for a charge/discharge cycle. Some days are more profitable than others and some days the savings may not justify using the battery due to battery aging.The storage system has an investment cost and a finite lifetime.
Do you somehow factor in the cost of using a kWh in EMHASS or do you simply hope that the difference in price between charge/discharge exceed the cost of the investment per kWh every day?
Warmly, Per
EMHASS doesn’t currently take into account battery degradation in its costing model. I suppose you could use a lower efficiency value to represent a reduced value. EMHASS is really good for doing what if analysis for the impact if you double battery size or solar array size.
EMHASS does take account of the cost to charge and discharge, including efficiency and depending on the cost model you select will only charge/ discharge your battery if it meets the objectives of maximise profit or self consumption.
Have a look at the Web UI, to see the details for each time period.
I do have some templates that calculate the daily savings from battery and solar. But that is interested to EMHASS.
that
