I’m trying to configure emhass on my home assistant installation running on a Raspberry Pi 4 rpi4-64.
I’ll get errors when using my selected pv_module and pv_inverter. Maybe I don’t apply the right number of _? or is there a bug?
I figured out which pv-module is most similar to my panels (as my panels from Bauer are not listed in the csv file), so I choose:
Vietnam Sunergy Joint Stock Company VSUN380-120BMH
Same for the inverter, but luckily the vendor exist, only diff is that my inverter is a 4.6KTL:
Huawei Technologies Co Ltd : SUN2000-5KTL-USL0 [240V]
When applying config, starting emhass and launching day-ahead optimization from the web-ui I get following log entries:
s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting services-up: info: copying legacy longrun emhass (no readiness notification) s6-rc: info: service legacy-services successfully started [2022-07-27 23:23:23,463] INFO in web_server: Launching the emhass webserver at: http://0.0.0.0:5000 [2022-07-27 23:23:23,464] INFO in web_server: Home Assistant data fetch will be performed using url: http://supervisor/core/api [2022-07-27 23:23:23,466] INFO in web_server: The base path is: /usr/src [2022-07-27 23:23:23,474] INFO in web_server: Using core emhass version: 0.3.17 [2022-07-27 23:23:32,087] INFO in web_server: EMHASS server online, serving index.html... [2022-07-27 23:24:21,390] INFO in command_line: Setting up needed data [2022-07-27 23:24:21,479] INFO in forecast: Retrieving weather forecast data using method = scrapper [2022-07-27 23:24:24,611] ERROR in app: Exception on /action/dayahead-optim [POST] Traceback (most recent call last): File "/root/.local/lib/python3.9/site-packages/pandas/core/indexes/base.py", line 3621, in get_loc return self._engine.get_loc(casted_key) File "pandas/_libs/index.pyx", line 136, in pandas._libs.index.IndexEngine.get_loc File "pandas/_libs/index.pyx", line 163, in pandas._libs.index.IndexEngine.get_loc File "pandas/_libs/hashtable_class_helper.pxi", line 5198, in pandas._libs.hashtable.PyObjectHashTable.get_item File "pandas/_libs/hashtable_class_helper.pxi", line 5206, in pandas._libs.hashtable.PyObjectHashTable.get_item KeyError: 'Vietnam_Sunergy_Joint_Stock_Company_VSUN380_120BMH' The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 2077, in wsgi_app response = self.full_dispatch_request() File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1525, in full_dispatch_request rv = self.handle_user_exception(e) File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1523, in full_dispatch_request rv = self.dispatch_request() File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1509, in dispatch_request return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args) File "/usr/local/lib/python3.9/dist-packages/emhass/web_server.py", line 134, in action_call input_data_dict = set_input_data_dict(config_path, str(config_path.parent), costfun, File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 76, in set_input_data_dict P_PV_forecast = fcst.get_power_from_weather(df_weather) File "/usr/local/lib/python3.9/dist-packages/emhass/forecast.py", line 317, in get_power_from_weather module = cec_modules[self.plant_conf['module_model'][i]] File "/root/.local/lib/python3.9/site-packages/pandas/core/frame.py", line 3505, in __getitem__ indexer = self.columns.get_loc(key) File "/root/.local/lib/python3.9/site-packages/pandas/core/indexes/base.py", line 3623, in get_loc raise KeyError(key) from err KeyError: 'Vietnam_Sunergy_Joint_Stock_Company_VSUN380_120BMH'
When replacing the pv-module name in the config with the documentation example:
CSUN_Eurasia_Energy_Systems_Industry_and_Trade_CSUN295_60M
I’ll get this:
s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting services-up: info: copying legacy longrun emhass (no readiness notification) s6-rc: info: service legacy-services successfully started [2022-07-27 23:34:08,710] INFO in web_server: Launching the emhass webserver at: http://0.0.0.0:5000 [2022-07-27 23:34:08,710] INFO in web_server: Home Assistant data fetch will be performed using url: http://supervisor/core/api [2022-07-27 23:34:08,711] INFO in web_server: The base path is: /usr/src [2022-07-27 23:34:08,718] INFO in web_server: Using core emhass version: 0.3.17 [2022-07-27 23:34:21,858] INFO in web_server: EMHASS server online, serving index.html... [2022-07-27 23:34:33,264] INFO in command_line: Setting up needed data [2022-07-27 23:34:33,353] INFO in forecast: Retrieving weather forecast data using method = scrapper [2022-07-27 23:34:35,533] ERROR in app: Exception on /action/dayahead-optim [POST] Traceback (most recent call last): File "/root/.local/lib/python3.9/site-packages/pandas/core/indexes/base.py", line 3621, in get_loc return self._engine.get_loc(casted_key) File "pandas/_libs/index.pyx", line 136, in pandas._libs.index.IndexEngine.get_loc File "pandas/_libs/index.pyx", line 163, in pandas._libs.index.IndexEngine.get_loc File "pandas/_libs/hashtable_class_helper.pxi", line 5198, in pandas._libs.hashtable.PyObjectHashTable.get_item File "pandas/_libs/hashtable_class_helper.pxi", line 5206, in pandas._libs.hashtable.PyObjectHashTable.get_item KeyError: 'Huawei_Technologies_Co_Ltd___SUN2000_5KTL_USL0__240V_' The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 2077, in wsgi_app response = self.full_dispatch_request() File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1525, in full_dispatch_request rv = self.handle_user_exception(e) File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1523, in full_dispatch_request rv = self.dispatch_request() File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1509, in dispatch_request return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args) File "/usr/local/lib/python3.9/dist-packages/emhass/web_server.py", line 134, in action_call input_data_dict = set_input_data_dict(config_path, str(config_path.parent), costfun, File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 76, in set_input_data_dict P_PV_forecast = fcst.get_power_from_weather(df_weather) File "/usr/local/lib/python3.9/dist-packages/emhass/forecast.py", line 318, in get_power_from_weather inverter = cec_inverters[self.plant_conf['inverter_model'][i]] File "/root/.local/lib/python3.9/site-packages/pandas/core/frame.py", line 3505, in __getitem__ indexer = self.columns.get_loc(key) File "/root/.local/lib/python3.9/site-packages/pandas/core/indexes/base.py", line 3623, in get_loc raise KeyError(key) from err KeyError: 'Huawei_Technologies_Co_Ltd___SUN2000_5KTL_USL0__240V_'
