Thanks for these inputs. I’m still evaluating if it worths the effort.
This is very interesting and it is a great idea to try to standardize interfaces and communication protocols.
There is a similar effort in the multi physics simulation world using FMI/FMU models.
Unfortunately for this EFI effort it seems quite dead. The last update to the github was 6 years ago and I couldn’t find a lot of information and documentation.
This seems like a very powerful tool thanks for sharing.
I am on amber, but don’t yet have solar or a battery. I am wanting to setup rules (either in node red or this tool) to look at the forecast of power and do the following for example:
- if someone turns on the dryer (I have smart power switch on it) and price is expensive - and will be much cheaper in the next 5 hours to turn it off and remind us to turn it on later.
Pretty much that. I also have ecebee turn off etc if it’s expensive but this app seems like it can be used for this even if i don’t have solar or battery is that true?
thank you
EMHASS works well even without a battery or solar system, as it can provide an optimized schedule based on price alone and then switch your devices according to that plan.
I also use Amber and have set up automations that trigger based on their dynamic pricing. For instance, I have rules in place for my dryer to switch on when Amber prices are low (green) and switch off when prices are high (yellow/red). It’s an efficient way to manage energy usage for a few devices.
However, if you’re looking to manage multiple devices, EMHASS is the way to go, as it can optimize the energy usage for all your devices simultaneously. This helps maximize savings and maintain a more sustainable household. I’ve found this combination of EMHASS and Amber to be incredibly useful in managing my home’s energy consumption effectively.
thanks so much. ill take a good look.
how do you turn your dryer on - i assume it doesn’t have touch panels? ours has on off and start touch panels but i can’t turn it on with the smart switch which sucks. but i can turn it off and then announce when to turn it on.
My old dryer and dishwasher, if I start the cycle then turn off the smart switch, it will resume the cycle when the power comes back on.
My new heat pump dryer uses a lot less power 600W down from 2kW and has a home assistant remote start option:
Unfortunately I suddenly got some problems with EMHASS.
I installed the latest update for Home Assistant and since then, I get the error of an empty JSON.
My json:
{"pv_power_forecast":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,14.6,65.35000000000001,133.8,302.75,544.5,832.75,1142.45,1447.05,1686.75,1875.85,2040.05,2084.55], "prod_price_forecast":[0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457,0.14457], "load_cost_forecast":[0.234036,0.230366,0.230366,0.223456,0.223456,0.210182,0.210182,0.214396,0.214396,0.202506,0.202506,0.198168,0.198168,0.199218,0.199218,0.198514,0.198514,0.199911,0.199911,0.198761,0.198761,0.197352,0.197352,0.189775,0.189775,0.179554,0.179554,0.149791,0.149791,0.121894], "prediction_horizon":30, "def_total_hours":[0.00], "alpha":0.5, "beta":0.5}
log:
2023-05-06T18:52:08.139145771Z stdout UnboundLocalError: local variable 'df_day' referenced before assignment
2023-05-06T18:52:08.139074920Z stdout self.df_final = pd.concat([self.df_final, df_day], axis=0)
2023-05-06T18:52:08.139009681Z stdout File "/usr/local/lib/python3.8/site-packages/emhass-0.4.8-py3.8.egg/emhass/retrieve_hass.py", line 147, in get_data
2023-05-06T18:52:08.138952880Z stdout rh.get_data(days_list, var_list)
2023-05-06T18:52:08.138724339Z stdout File "/usr/local/lib/python3.8/site-packages/emhass-0.4.8-py3.8.egg/emhass/forecast.py", line 585, in get_load_forecast
2023-05-06T18:52:08.138650588Z stdout P_load_forecast = fcst.get_load_forecast(method=optim_conf['load_forecast_method'], set_mix_forecast=True, df_now=df_input_data)
2023-05-06T18:52:08.138584837Z stdout File "/usr/local/lib/python3.8/site-packages/emhass-0.4.8-py3.8.egg/emhass/command_line.py", line 120, in set_input_data_dict
2023-05-06T18:52:08.138515323Z stdout input_data_dict = set_input_data_dict(config_path, str(data_path), costfun,
2023-05-06T18:52:08.138458610Z stdout File "src/emhass/web_server.py", line 170, in action_call
2023-05-06T18:52:08.138400534Z stdout return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
2023-05-06T18:52:08.138341945Z stdout File "/usr/local/lib/python3.8/site-packages/flask/app.py", line 1799, in dispatch_request
2023-05-06T18:52:08.138287669Z stdout rv = self.dispatch_request()
2023-05-06T18:52:08.138228431Z stdout File "/usr/local/lib/python3.8/site-packages/flask/app.py", line 1823, in full_dispatch_request
2023-05-06T18:52:08.138175105Z stdout rv = self.handle_user_exception(e)
2023-05-06T18:52:08.138112429Z stdout File "/usr/local/lib/python3.8/site-packages/flask/app.py", line 1825, in full_dispatch_request
2023-05-06T18:52:08.138054291Z stdout response = self.full_dispatch_request()
2023-05-06T18:52:08.137979027Z stdout File "/usr/local/lib/python3.8/site-packages/flask/app.py", line 2528, in wsgi_app
2023-05-06T18:52:08.137922238Z stdout Traceback (most recent call last):
2023-05-06T18:52:08.137832824Z stdout 2023-05-06 20:52:08,137 - web_server - ERROR - Exception on /action/naive-mpc-optim [POST]
2023-05-06T18:52:08.137516519Z stdout 2023-05-06 20:52:08,136 - web_server - ERROR - Either the names of the passed variables are not correct or days_to_retrieve is larger than the recorded history of your sensor (check your recorder settings)
2023-05-06T18:52:08.137313341Z stdout 2023-05-06 20:52:08,136 - web_server - ERROR - The retrieved JSON is empty, check that correct day or variable names are passed
2023-05-06T18:52:08.120239184Z stdout 2023-05-06 20:52:08,119 - web_server - INFO - Retrieve hass get data method initiated...
2023-05-06T18:52:08.118733146Z stdout 2023-05-06 20:52:08,118 - web_server - INFO - Retrieving data from hass for load forecast using method = naive
2023-05-06T18:52:08.114915583Z stdout 2023-05-06 20:52:08,114 - web_server - INFO - Retrieving weather forecast data using method = list
2023-05-06T18:52:02.659197136Z stdout 2023-05-06 20:52:02,658 - web_server - INFO - Retrieve hass get data method initiated...
2023-05-06T18:52:02.650789122Z stdout 2023-05-06 20:52:02,650 - web_server - INFO - Setting up needed data
The json itself wasn’t changed and I also created a new long-lived token and set it in the secrets-yaml.
Any idea?
Thanks!
My use case:
- Have PV generation (no batteries)
- Want to control my boiler heat resistance so it turns one when PV is generating more power than what the house consumes
- Have flat energy rate
I configured EMHASS so that energy cost is higher during non-peak hours (as an attempt to influence the model believe it is NOT a good timing to turn my heat resistance) but since some weeks of gathering stats, it’s still saying it’s OK to connect the resistance in non peak hours:
ps:
- Shelly–> PV generation > house consumption for >1500w (basically I’m injecting energy in the grid over 1500w)
- EMHASS → EMHASS cost function model results
Question: setting a higher cost during non peak hours makes sense for my use case?
No idea about this, I haven’t seen these issues on my install. But this seems related to the long lived access token. Did you try restarting your system?
I don’t understand what are you trying to achieve, but if you want this kind of action then just setup an automation to do that.
EMHASS is an optimization, so the results are the reflect of the maximum possible profit for your system (if you choose that as the objective function).
Peak and non peak hours are related to power consumption not to PV production, so I really don’t understand how could that makes sense. But may be as I said I don’t understand what are you trying to achieve.
Yes I restarted home assistant and EMHASS.
I activated MFA a few days before it stopped working.
Might this be related?
EDIT: I don’t know why but without any further changes, it started working again over night
I’m just in the process of getting this all working… It seems I need to wait some time for there to be enough data in HA for the new ML function to work.
In the meantime, setting up the entity for var_load… sensor.power_load_no_var_loads, just want to clarify if I’ve understanding this right…
I’ve got PV and a 12KWh battery. Is the battery counted as a deferrable load? Does that mean I need to include it in the power_load_no_var_loads template to be subtracted when it’s charging? There’s no differentiation between when it’s being charged by the grid or by the PV is there? Is this OK?
This is how I’ve defined the template sensor. Does this look correct to you?
- sensor:
- name: "Power load no var loads"
unit_of_measurement: "W"
device_class: "power"
state: >
{% set powerload = states('sensor.home_consumption') | float(default=0) %}
{% set ac = states('sensor.power_aircon') | float(default=0) %}
{% set ev = states('sensor.power_ev_charger') | float(default=0) %}
{% set utility = states('sensor.power_utility_room') | float(default=0) %}
{% set battery = states('sensor.battery_charge_rate') | float(default=0) %}
{% set value = ( powerload - ac - ev - utility - battery ) | round(1,default=0) %}
{{ value }}
sensor.home_consumption is my total power draw for the home (including EV charger, AC, battery charge from grid, etc)
No it is not. Don’t include in the sensor template.
This will be handled inside the optimization code. You don’t need to do anything about this.
There is an option to constrain to only charge your battery from PV. Set set_nocharge_from_grid: true
Great, thanks a lot.
Will you be updating the add-on at some point? I notice in the main emhass repo, you changed days_to_retrieve = 30 to 9. But haven’t released this as a new version yet.
It will be available in the next release yes.
Not enough time lately to work on this but it will be updated anytime soon.
Anyone here with deye inverters? I have made the possibility to change the wanted soc from the emhass recommended soc. But the issue for me is that the battery will be fully charged within the expensive grid hours and later that day i will be giving away free energy. Have anyone solved this some how limiting the pv power to charge batteries when using zero export to ct?
I have found a way to set charging amps down on the deye inverter using modbus same way as setting wanted soc. But is it a recommended way doing this using p_batt_forcast?
unit_of_measurement: W
friendly_name: Battery Power Forecast
battery_scheduled_power:
- date: '2023-05-19 10:00:00+02:00'
p_batt_forecast: '-380.0'
- date: '2023-05-19 11:00:00+02:00'
p_batt_forecast: '0.0'
- date: '2023-05-19 12:00:00+02:00'
- date: '2023-05-19 13:00:00+02:00'
p_batt_forecast: '-3242.0'
- date: '2023-05-19 14:00:00+02:00'
- date: '2023-05-19 15:00:00+02:00'
p_batt_forecast: '-493.0'
- date: '2023-05-19 16:00:00+02:00'
p_batt_forecast: '-698.0'
- date: '2023-05-19 17:00:00+02:00'
p_batt_forecast: '354.0'
- date: '2023-05-19 18:00:00+02:00'
p_batt_forecast: '411.0'
- date: '2023-05-19 19:00:00+02:00'
p_batt_forecast: '-1147.0'
- date: '2023-05-19 20:00:00+02:00'
p_batt_forecast: '-206.0'
- date: '2023-05-19 21:00:00+02:00'
p_batt_forecast: '989.0'
nordpool:
raw_today:
- start: '2023-05-19T00:00:00+02:00'
end: '2023-05-19T01:00:00+02:00'
value: 0.969
- start: '2023-05-19T01:00:00+02:00'
end: '2023-05-19T02:00:00+02:00'
value: 0.941
- start: '2023-05-19T02:00:00+02:00'
end: '2023-05-19T03:00:00+02:00'
value: 0.907
- start: '2023-05-19T03:00:00+02:00'
end: '2023-05-19T04:00:00+02:00'
value: 0.871
- start: '2023-05-19T04:00:00+02:00'
end: '2023-05-19T05:00:00+02:00'
value: 0.887
- start: '2023-05-19T05:00:00+02:00'
end: '2023-05-19T06:00:00+02:00'
value: 0.918
- start: '2023-05-19T06:00:00+02:00'
end: '2023-05-19T07:00:00+02:00'
value: 0.972
- start: '2023-05-19T07:00:00+02:00'
end: '2023-05-19T08:00:00+02:00'
value: 1.201
- start: '2023-05-19T08:00:00+02:00'
end: '2023-05-19T09:00:00+02:00'
value: 1.19
- start: '2023-05-19T09:00:00+02:00'
end: '2023-05-19T10:00:00+02:00'
value: 1.028
- start: '2023-05-19T10:00:00+02:00'
end: '2023-05-19T11:00:00+02:00'
value: 0.831
- start: '2023-05-19T11:00:00+02:00'
end: '2023-05-19T12:00:00+02:00'
value: 0.707
- start: '2023-05-19T12:00:00+02:00'
end: '2023-05-19T13:00:00+02:00'
value: 0.708
- start: '2023-05-19T13:00:00+02:00'
end: '2023-05-19T14:00:00+02:00'
value: 0.678
- start: '2023-05-19T14:00:00+02:00'
end: '2023-05-19T15:00:00+02:00'
value: 0.677
- start: '2023-05-19T15:00:00+02:00'
end: '2023-05-19T16:00:00+02:00'
value: 0.75
- start: '2023-05-19T16:00:00+02:00'
end: '2023-05-19T17:00:00+02:00'
value: 0.835
- start: '2023-05-19T17:00:00+02:00'
end: '2023-05-19T18:00:00+02:00'
value: 0.968
- start: '2023-05-19T18:00:00+02:00'
end: '2023-05-19T19:00:00+02:00'
value: 1.069
- start: '2023-05-19T19:00:00+02:00'
end: '2023-05-19T20:00:00+02:00'
value: 1.067
- start: '2023-05-19T20:00:00+02:00'
end: '2023-05-19T21:00:00+02:00'
value: 1.063
- start: '2023-05-19T21:00:00+02:00'
end: '2023-05-19T22:00:00+02:00'
value: 1.057
- start: '2023-05-19T22:00:00+02:00'
end: '2023-05-19T23:00:00+02:00'
value: 1.053
- start: '2023-05-19T23:00:00+02:00'
end: '2023-05-20T00:00:00+02:00'
value: 0.971
I do the same to set the charging_amps for my EV:
Charging Amps = Power / Phases / Voltage
Just be careful with the charging and discharging (negative and positive values) and what your MODBUS expects.
service: number.set_value
value: >-
{{(states('sensor.p_deferrable2')|int(0) /
(state_attr('sensor.duka_charger_power','charger_phases')*3/2)|int(1) /
max(220,state_attr('sensor.duka_charger_power','charger_volts')|int(230)))|round(0)}}
entity_id: number.duka_charging_amps
thanks for your answer, so my example provided data was not good since the prices are almost the same and there was low PV, but the other day there was high pv and later the day the energy was free. So I want to find a fix for this instead charge battery when energy is expensive from PV I do want to sell pv and later that day if the analyze expect free energy or high pv or the combination of both we can delay charging until then.
This is not possible to read from the data that emhass generates? If this is not expeced my inverters can just stay in max charg amps 24/7 and just adjust soc. This will also lower the grid voltage on the day with high pv and maximize earning.
Forgot to say that this is the battery for the solar inverter I want to do this on.
