EMHASS: An Energy Management for Home Assistant
At first I have deleted the load_zonder_wp_forecast_mlf.pkl file, then I have changed to 10 days and the same problem…
❯ curl -i -H 'Content-Type: application/json' -X POST -d '{
    "days_to_retrieve": 10,
    "model_type": "load_zonder_wp_forecast",
    "var_model": "sensor.huidig_verbruik_zonder_wp",
    "sklearn_model": "KNeighborsRegressor",
    "num_lags": 48,
    "split_date_delta": "48h",
    "perform_backtest": "True"
    }' http://192.168.79.54:5001/action/forecast-model-fit
HTTP/1.1 201 CREATED
Content-Length: 49
Content-Type: text/html; charset=utf-8
Date: Thu, 08 Jun 2023 10:52:19 GMT
Server: waitress
EMHASS >> Action forecast-model-fit executed...
    ~          27s 
    "model_predict_publish": "True",
    "model_predict_entity_id": "sensor.p_load_zonder_wp_custom_model",
    "model_predict_unit_of_measurement": "W",
    "model_predict_friendly_name": "Warmtepompboiler custom model"
    }' http://192.168.79.54:5001/action/forecast-model-predict
HTTP/1.1 500 INTERNAL SERVER ERROR
Content-Length: 265
Date: Thu, 08 Jun 2023 10:53:04 GMT
Server: waitress
<!doctype html>
<html lang=en>
<title>500 Internal Server Error</title>
<h1>Internal Server Error</h1>
<p>The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.</p>
Logs from the addon
2023-06-08 12:52:19,062 - web_server - INFO - Setting up needed data
2023-06-08 12:52:19,068 - web_server - INFO - Retrieve hass get data method initiated...
2023-06-08 12:52:44,891 - web_server - INFO -  >> Performing a machine learning forecast model fit...
2023-06-08 12:52:44,892 - web_server - INFO - Performing a forecast model fit for load_zonder_wp_forecast
2023-06-08 12:52:44,899 - web_server - INFO - Training a KNeighborsRegressor model
2023-06-08 12:52:44,926 - web_server - INFO - Elapsed time for model fit: 0.026717424392700195
2023-06-08 12:52:45,132 - web_server - INFO - Prediction R2 score of fitted model on test data: -0.009545803507708062
2023-06-08 12:52:45,135 - web_server - INFO - Performing simple backtesting of fitted model
  0%|          | 0/8 [00:00<?, ?it/s]
 25%|██▌       | 2/8 [00:00<00:00, 17.07it/s]
 50%|█████     | 4/8 [00:00<00:00, 17.42it/s]
 75%|███████▌  | 6/8 [00:00<00:00, 16.90it/s]
100%|██████████| 8/8 [00:00<00:00, 19.05it/s]
2023-06-08 12:52:45,559 - web_server - INFO - Elapsed backtesting time: 0.42389512062072754
2023-06-08 12:52:45,560 - web_server - INFO - Backtest R2 score: 0.45701203567639437
2023-06-08 12:53:04,109 - web_server - INFO - Setting up needed data
2023-06-08 12:53:04,115 - web_server - INFO - Retrieve hass get data method initiated...
2023-06-08 12:53:04,139 - web_server - ERROR - The retrieved JSON is empty, check that correct day or variable names are passed
2023-06-08 12:53:04,140 - web_server - ERROR - Either the names of the passed variables are not correct or days_to_retrieve is larger than the recorded history of your sensor (check your recorder settings)
2023-06-08 12:53:04,142 - web_server - ERROR - Exception on /action/forecast-model-predict [POST]
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 2190, in wsgi_app
    response = self.full_dispatch_request()
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1486, in full_dispatch_request
    rv = self.handle_user_exception(e)
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1484, in full_dispatch_request
    rv = self.dispatch_request()
  File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1469, in dispatch_request
    return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
  File "/usr/local/lib/python3.9/dist-packages/emhass/web_server.py", line 174, in action_call
    input_data_dict = set_input_data_dict(config_path, str(data_path), costfun,
  File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 146, in set_input_data_dict
    rh.get_data(days_list, var_list)
  File "/usr/local/lib/python3.9/dist-packages/emhass/retrieve_hass.py", line 147, in get_data
    self.df_final = pd.concat([self.df_final, df_day], axis=0)
UnboundLocalError: local variable 'df_day' referenced before assignment
And when trying the tune
    }' http://192.168.79.54:5001/action/forecast-model-tune
Content-Length: 265
Date: Thu, 08 Jun 2023 11:49:13 GMT
Server: waitress
<!doctype html>
<html lang=en>
Errors in the addon log
2023-06-08 13:49:13,471 - web_server - ERROR - Either the names of the passed variables are not correct or days_to_retrieve is larger than the recorded history of your sensor (check your recorder settings)
2023-06-08 13:49:13,471 - web_server - ERROR - Exception on /action/forecast-model-tune [POST]
Thanks. Progressing here. Now I run into another issue, which I believe might have to do with timestamp formatting from HA on last_changed or last_updated attributes. Sometimes they have microseconds, but that doesn’t seem to be appreciated by emhass. As you can see in my post above, the timestamps from the pv power sensor somethimes has “%Y-%m-%dT%H:%M:%S.%f%z” format…
> emhass --action 'dayahead-optim' --config './' --costfun 'profit'
C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Lib\site-packages\pvlib\forecast.py:20: UserWarning: The forecast module algorithms and features are highly experimental. The API may change, the functionality may be consolidated into an io module, or the module may be separated into its own package.
  warnings.warn(
2023-06-08 16:28:34,558 - emhass.command_line - INFO - Setting up needed data
INFO:emhass.command_line:Setting up needed data
2023-06-08 16:28:34,665 - emhass.command_line - INFO - Retrieve hass get data method initiated...
INFO:emhass.command_line:Retrieve hass get data method initiated...
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Scripts\emhass.exe\__main__.py", line 7, in <module>
  File "C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Lib\site-packages\emhass\command_line.py", line 182, in main
    input_data_dict = setUp(config_path, costfun, logger)
  File "C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Lib\site-packages\emhass\command_line.py", line 37, in setUp
    rh.get_data(days_list, var_list,
  File "C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Lib\site-packages\emhass\retrieve_hass.py", line 101, in get_data
    from_date = pd.to_datetime(df_raw['last_changed']).min()
  File "C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Lib\site-packages\pandas\core\tools\datetimes.py", line 1050, in to_datetime
    values = convert_listlike(arg._values, format)
  File "C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Lib\site-packages\pandas\core\tools\datetimes.py", line 453, in _convert_listlike_datetimes
    return _array_strptime_with_fallback(arg, name, utc, format, exact, errors)
  File "C:\Users\Ivar\Documents\Programmering\Python\emhass\emhassenv\Lib\site-packages\pandas\core\tools\datetimes.py", line 484, in _array_strptime_with_fallback
    result, timezones = array_strptime(arg, fmt, exact=exact, errors=errors, utc=utc)
  File "pandas\_libs\tslibs\strptime.pyx", line 530, in pandas._libs.tslibs.strptime.array_strptime
  File "pandas\_libs\tslibs\strptime.pyx", line 351, in pandas._libs.tslibs.strptime.array_strptime
ValueError: time data "2023-06-07T14:07:02.986111+00:00" doesn't match format "%Y-%m-%dT%H:%M:%S%z", at position 1. You might want to try:
    - passing `format` if your strings have a consistent format;
    - passing `format='ISO8601'` if your strings are all ISO8601 but not necessarily in exactly the same format;
    - passing `format='mixed'`, and the format will be inferred for each element individually. You might want to use `dayfirst` alongside this.
In the NL we currently have a big problem where eletricity prices can go extremely negative due to massive growth of PV infeed in recent years. Last week we had prices of up to MINUS 0.60 euro per kWh (day head reached the absolute minimum at -400 euro / MWh!), absolutely crazy and it’s going to get much worse before it gets better. For people with solar panels and a dynamic hourly energy contract this is terrible ofcourse.
EMHASS can help with this but what would be the best way? I prefer not to use a relay because then I would also lose the ability to consume my own PV energy. I basically need a dummy load to dump energy into whenever the price goes so far negative that it starts to cost me money (ofcourse after all deferrable loads have been planned).
But during that hour, wouldn’t it be better to just not use PV but import from grid instead? You wouldn’t lose anything by not using your own PV energy.
We have a similar situation in Sweden, although nowhere near those prices. I’ve seen 0.03€/kWh on occasion and it’s not really worth avoiding as a few hours later, prices are positive again. However, I see a point in waiting with battery charge to those hours and also set my inverter to zero export. If the price dip comes when the sun doesn’t shine, I’d use grid power to charge the battery.
Yeah I have thought about that. It makes sense on an individual basis if you purely look at the finances. But if we consider the entire network I think it would be better if instead of shutting off solar panels and losing energy we would all consume our own energy as much as possible. You might even be paid for that in the future.
I don’t view this as a problem or a terrible outcome. This is a success in the transition to sustainable energy and there are real productivity benefits for a nation as well as individuals for the price of energy to go this low. Business can offer things like ‘free’ EV charging, high energy processes like water heating and HVAC can soak up this additional energy improving quality of life for very little cost.
In AU over summer we offer see the sell price for electricity go negative for 6-8 hours a day and even the buy cost go negative over the midday solar soak.
One of my key observations is following EMHASS recommendations is don’t let your battery fill too early. If your battery is full by 1000 but the latest prices of the day are at 1200 then you aren’t optimising. In this case EMHASS will generally delay charging the battery until maybe 1000 or 1100 so it can then be filled during the cheapest time of the day.
It also helps greatly if your loads match/ exceed your solar production capability. I have a 15 kW solar inverter but initially only had a battery with 5 kW power rating, EMHASS was able to schedule my other loads to make up the shortfall; 11 kW EV charging, 5 kW pool heat pump, 10 kW HVAC. In fact when the prices go that low EMHASS schedules those devices to consume additional energy from the grid which actually helps everyone by soaking up the oversupply.
My final strategy when fully charged is curtailment. Home Assistant switches my SolarEdge inverter to zero export mode when the sell price is below zero and zero production mode when the buy cost is below zero. This means I’m not contributing to the issue of oversupply (which is what negative prices mean) but actually consuming the excess which allows others to export.
Love it Mark… great perspective!
not work:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun emhass (no readiness notification)
s6-rc: info: service legacy-services successfully started
2023-06-10 12:54:21,365 - web_server - INFO - Launching the emhass webserver at: http://0.0.0.0:5000
2023-06-10 12:54:21,366 - web_server - INFO - Home Assistant data fetch will be performed using url: http://supervisor/core/api
2023-06-10 12:54:21,367 - web_server - INFO - The data path is: /share
2023-06-10 12:54:21,371 - web_server - INFO - Using core emhass version: 0.4.12
waitress   INFO  Serving on http://0.0.0.0:5000
2023-06-10 12:54:59,043 - web_server - INFO - EMHASS server online, serving index.html...
2023-06-10 12:54:59,056 - web_server - WARNING - The data container dictionary is empty... Please launch an optimization task
2023-06-10 12:55:42,583 - web_server - INFO - Setting up needed data
2023-06-10 12:55:42,665 - web_server - INFO - Retrieve hass get data method initiated...
2023-06-10 12:55:42,702 - web_server - ERROR - The retrieved JSON is empty, check that correct day or variable names are passed
2023-06-10 12:55:42,702 - web_server - ERROR - Either the names of the passed variables are not correct or days_to_retrieve is larger than the recorded history of your sensor (check your recorder settings)
2023-06-10 12:55:42,703 - web_server - ERROR - Exception on /action/perfect-optim [POST]
  File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 78, in set_input_data_dict
Also python is on either 3.10 or 3.11 currently in the releases. My question is why has yours not updated? The RED line error.
That error has absolutely nothing to do with a Python version. Python 3.9 is still completely supported but yes we should update to 3.10. Just have to find the time to test that :+1:
My curl command is getting quite complex to manage:
I have now switched to a dedicated rest_command, which is still complex, but less so I also get errors reported in the logs directly, which is helpful:
rest_command:
  naive_mpc_optim:
    url: http://localhost:5000/action/naive-mpc-optim
    method: POST
    content_type: 'application/json'
    payload: >-
        "prod_price_forecast": {{
          ([states('sensor.amber_feed_in_price')|float(0)] +
          (state_attr('sensor.amber_feed_in_forecast', 'forecasts')|map(attribute='per_kwh')|list))
          | tojson
        "load_cost_forecast": {{
          ([states('sensor.amber_general_price')|float(0)] +
          state_attr('sensor.amber_general_forecast', 'forecasts') |map(attribute='per_kwh')|list)
          | tojson
        "load_power_forecast": {{
          ([states('sensor.power_load_no_var_loads')|int] +
          (states('input_text.fi_fo_buffer').split(', ')|map('multiply',1000)|map('int')|list)[1:]
          )| tojson
        "pv_power_forecast": {{
          ([states('sensor.APF_Generation_Entity')|int(0)] +
          state_attr('sensor.solcast_forecast_today', 'detailedForecast')|selectattr('period_start','gt',utcnow()) | map(attribute='pv_estimate')|map('multiply',2000)|map('int')|list +
          state_attr('sensor.solcast_forecast_tomorrow', 'detailedForecast')|selectattr('period_start','gt',utcnow()) | map(attribute='pv_estimate')|map('multiply',2000)|map('int')|list
          )| tojson
        "prediction_horizon": {{
          min(48, (state_attr('sensor.amber_feed_in_forecast', 'forecasts')|map(attribute='per_kwh')|list|length)+1)
        "alpha": 1,
        "beta": 0,
        "num_def_loads": 6,
        "def_total_hours": {{[states('sensor.def_total_hours_pool_filter')|int(0),
                              states('sensor.def_total_hours_pool_heatpump')|int(0),
                              states('sensor.def_total_hours_ev')|int(0),
                              states('sensor.def_total_hours_hvac')|int(0),
                              states('sensor.def_total_hours_hws')|int(0),
                              states('input_number.car2_def_total_hours')|int(0)]}},
        "P_deferrable_nom": [1300, 5000, 11500, 4000, 600, 3500],
        "treat_def_as_semi_cont": [1, 1, 0, 0, 1, 0],
        "set_def_constant": [0, 0, 0, 0, 0, 0],
        "soc_init": {{ (states('sensor.filtered_powerwall_soc')|int(0))/100 }},
        "soc_final": 0.0
  publish_data:
    url: http://localhost:5000/action/publish-data
    method: POST
    payload: '{}'
Done! Python 3.10 is now supported.
Possible Python versions are 3.8, 3.9 and 3.10
Hi
Trying to set up EMHASS but finding the instructions difficult. Would be very appreciative of some help.
  • I have 5kW PV.
  • A Fronius Primo 6.0-1 inverter.
  • I’m using solcast to predict PV production.
  • A 10 kWh (9 kWh usable) sonnen eco 9.43 battery.
  • I use the Sonnenbatterie HACS addon by weltmeyer to obtain all the battery metrics.
  • I can use POST to switch the battery between charge, discharge, self consumption and TOU modes and probably others that I haven’t discovered yet.
  • I’m on the Australian Amber Electric service (They don’t support Sonnen).
  • I’m using the Amber Electric integration in HA to get the pricing data etc.
  • Deferable loads might be pool pump, dish washer, dryer, washing machine but I currently don’t monitor power consumption for any of these loads.
  • I have one EV, Tesla model Y.
  • I’ve been using Charge HQ to divert feed-in to the car but suspect I can replace that with EMHASS.
I’ve set up the following in HA:
  • Automation
- alias: EMHASS day-ahead optimization
    platform: time
    at: 05:30:00
  - service: shell_command.dayahead_optim
- alias: EMHASS publish data
  - minutes: /5
    platform: time_pattern
  - service: shell_command.publish_data
  • configuration.yaml
shell_command:
  dayahead_optim: "curl -i -H \"Content-Type: application/json\" -X POST -d '{}' http://localhost:5000/action/dayahead-optim"
  publish_data: "curl -i -H \"Content-Type: application/json\" -X POST -d '{}' http://localhost:5000/action/publish-data"
  post_amber_forecast: "curl -i -H 'Content-Type: application/json' -X POST -d '{\"prod_price_forecast\":{{(
          }},\"load_cost_forecast\":{{(
          }},\"prediction_horizon\":33}' http://localhost:5000/action/dayahead-optim"
  post_emhass_forecast: "curl -i -H 'Content-Type: application/json' -X POST -d '{\"prod_price_forecast\":{{(
          }},{{states('sensor.solcast_24hrs_forecast')}},\"load_cost_forecast\":{{(
          }}}' http://localhost:5000/action/dayahead-optim"
  post_mpc_optim_solcast: "curl -i -H \"Content-Type: application/json\" -X POST -d '{\"load_cost_forecast\":{{(
          state_attr('sensor.amber_general_forecast', 'forecasts') |map(attribute='per_kwh')|list)[:48])
          }}, \"prod_price_forecast\":{{(
          ([states('sensor.cecil_st_feed_in_price')|float(0)] +
          state_attr('sensor.cecil_st_feed_in_forecast', 'forecasts')|map(attribute='per_kwh')|list)[:48])
          }}, \"pv_power_forecast\":{{states('sensor.solcast_24hrs_forecast')
          }}, \"prediction_horizon\":48,\"soc_init\":{{(states('sensor.sonnenbatterie_84324_state_charge_user')|float(0))/100
          }},\"soc_final\":0.05,\"def_total_hours\":[2,0,0,0]}' http://localhost:5000/action/naive-mpc-optim"
and
# Solar forecast for EMHASS
  - platform: rest
    name: "Solcast Forecast Data"
    json_attributes:
      - forecasts
    resource: https://api.solcast.com.au/rooftop_sites/YYYYYYYYYYYYY/forecasts?format=json&api_key=XXXXXXXXXXXXXXXXXXXXXXXXXX&hours=24
    method: GET
    value_template: "{{ (value_json.forecasts[0].pv_estimate)|round(2) }}"
    unit_of_measurement: "kW"
    device_class: power
    scan_interval: 8000
    force_update: true
    sensors:
      solcast_24hrs_forecast :
        value_template: >-
          {%- set power = state_attr('sensor.solcast_forecast_data', 'forecasts') | map(attribute='pv_estimate') | list %}
          {%- set values_all = namespace(all=[]) %}
          {% for i in range(power | length) %}
          {%- set v = (power[i] | float |multiply(1000) ) | int(0) %}
          {%- set values_all.all = values_all.all + [ v ] %}
          {%- endfor %} {{ (values_all.all)[:48] }}
I assume I have to change the automation to also call the amber, EMHASS and solcast curl shell commands? But not sure if this replaces the default dayahead_optim and publish_data curl commands.
Haven’t even looked into what I do with the returned results from EMHASS. Just wanted to get this first stage set up correctly.
Do I need to measure deferable loads so I can subtract them from house consumption figure I get from battery? If so, I’ll have to go out and gets some power points that monitor power.
Am I going about this in the right way. What changes do I need to make and what next.
Thanks in advance.
Looks like you have a lot of components.
I would start with a basic system.
If you can control your battery charge/ discharge via a post command, then you should be able to get the same level of functionality as SmartShift.
Your EV and pool pump will also integrate well and you should be able to get excellent optimisation results. You will need a smart socket for the pool but the EV should be able to integrate directly.
You only need to call one optimisation and one plublish content, the others are just spending that at in additional functionality.
As it is setup it will call the simple dayahead once a day at 0530 optimisation which is good and then publish these results every 5 minutes.
You can find my post here on how you can connect other devices:
Running Devices When Energy is Cheaper and Greener
@davidusb did you have a chance to look at the errors I posted above in EMHASS: An Energy Management for Home Assistant - #728 by Octofinger?
Seems emhass is choking on microseconds in HA sensor timestamps.
You have a problem retrieving your data from Home Assistant but with the given information I’m not able to reproduce that. I’m able to perfectly retrieve data from HA using the legacy Python code on a virtual environment, that’s proven to work so there must be a problem with your configuration.
You can maybe test using the standalone docker container, it is more practical to find the issue.
Otherwise open a new issue on github providing a way to reproduce the error.
Yes, I do have a basic system in place. I migrated to Node-Red about 4 years ago for automations.
  • Discharge battery when FiT goes above 51c and return to self-consumption when FiT goes below 49c
  • Charge the battery at 05:30 for a half hour if the amber general price is low and the battery is below 15% SoC
  • Charge the battery at 15:30 for an hour if the amber general price is low and the battery is below 80% SoC
  • Pool pump only comes on if the battery is 100% SoC and there is at least 1.5 kW PV for limited time depending on season
  • Turn on aircon and pool pump when FiT goes negative and battery is 100% SoC or PV Feed-in is positive
I don’t usually charge the car at home as there are too many free chargers located around me to bother, although that’s getting difficult with more and more EVs on the road.
Difficult limiting use of other loads (washing machines etc.) as people will use them whenever they want despite my focus on energy consumption, but I’m willing to try.
So, my main aim is to see what EMHASS will deliver to the logic. But it’s difficult to configure without reading through pages of hard to understand explanations of control systems. I don’t really need to know the details of MPC etc, just the different configuration steps to achieve the different modes of operation.
Just to make sure, you also get microseconds from HA in last_changed and last_updated timestamps? Or is it just me?
I’ll give the docker version a try.
Thanks for helping out!
No, I’ve never had these problems with microseconds. Your problem is with your configuration.
In the --config argument you need to pass the path with the yaml file included like this:
emhass --action 'dayahead-optim' --config './config_emhass.yaml' --costfun 'profit'
