I installed the Emhass addon and in the configuration changed the default sensor to:
- name: "Power_load_no_var_loads"
unit_of_measurement: "W"
device_class: power
state: >
{% set powerload = states('sensor.power_adresse_xx') | float(default=0) %}
{% set vvb = states('sensor.bryter_varmvannsbereder_electric_consumed_w') | float(default=0) %}
{% set vaskemaskin = states('sensor.strombryter_vaskemaskin_electrical_measurement') | float(default=0) %}
{% set value = ( powerload - vvb - vaskemaskin) | round(1,default=0) %}
{{ value }}
When I trigger a âPerfect optimizationâ or âDay-ahead optimizationâ I get error in the log. The recorded history of sensor.power_load_no_var_loads is only one day old. Is this error related to how many days the recorder has kept the data?
[2022-07-07 12:35:35,609] INFO in command_line: Setting up needed data
[2022-07-07 12:35:35,615] INFO in retrieve_hass: Retrieve hass get data method initiated...
[2022-07-07 12:35:35,652] ERROR in retrieve_hass: The retrieved JSON is empty, check that correct day or variable names are passed
[2022-07-07 12:35:35,653] ERROR in retrieve_hass: Either the names of the passed variables are not correct or days_to_retrieve is larger than the recorded history of your sensor (check your recorder settings)
[2022-07-07 12:35:35,653] ERROR in app: Exception on /action/perfect-optim [POST]
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 2077, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1525, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1523, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1509, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args)
File "/usr/local/lib/python3.9/dist-packages/emhass/web_server.py", line 134, in action_call
input_data_dict = set_input_data_dict(config_path, str(config_path.parent), costfun,
File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 64, in set_input_data_dict
rh.get_data(days_list, var_list,
File "/usr/local/lib/python3.9/dist-packages/emhass/retrieve_hass.py", line 130, in get_data
self.df_final = pd.concat([self.df_final, df_day], axis=0)
UnboundLocalError: local variable 'df_day' referenced before assignment
[2022-07-07 12:35:36,992] INFO in command_line: Setting up needed data
[2022-07-07 12:35:36,994] INFO in forecast: Retrieving weather forecast data using method = scrapper
[2022-07-07 12:35:39,318] INFO in forecast: Retrieving data from hass for load forecast using method = naive
[2022-07-07 12:35:39,319] INFO in retrieve_hass: Retrieve hass get data method initiated...
[2022-07-07 12:35:39,328] ERROR in retrieve_hass: The retrieved JSON is empty, check that correct day or variable names are passed
[2022-07-07 12:35:39,328] ERROR in retrieve_hass: Either the names of the passed variables are not correct or days_to_retrieve is larger than the recorded history of your sensor (check your recorder settings)
[2022-07-07 12:35:39,328] ERROR in app: Exception on /action/dayahead-optim [POST]
File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 77, in set_input_data_dict
P_load_forecast = fcst.get_load_forecast(method=optim_conf['load_forecast_method'])
File "/usr/local/lib/python3.9/dist-packages/emhass/forecast.py", line 476, in get_load_forecast
rh.get_data(days_list, var_list)
